rear springs for drag racing.
Old 11-02-2011, 07:58 PM
ryany's Avatar
Default rear springs for drag racing.
Ok I recently put a 12 bolt in my camaro and now it sits higher in the rear. I already have done the hose mod and still Is high. Any suggestions on getting it setting at a good stance.
Old 11-02-2011, 09:52 PM
hiltsy855's Avatar
Cut a 1/2 coil off the stock spring.
Old 11-02-2011, 10:16 PM
ryany's Avatar
Does anybody have a write up on how to do this. Its probably a dumb question but it dont hurt to ask.
Old 11-02-2011, 11:22 PM
SJMMFGINC's Avatar
Cutting the coils is a solution but one I really don't suggest. You could end up sitting on your bumpstops more often as you've changed your specs. I suppose one solution would be to change to lowered springs which has a higher progressive curve so you don't bottom out as easily even though its a shorter configuration.
You can change to coil overs where you can adjust the height to your liking easily Infinitely within a few inch range. This will allow you to change the spring rates easily too. PM or email me if you have more questions. I'm not on the boards as often as I like. When I have time, I try to help folks out in here.
Old 11-03-2011, 08:59 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
I wouldn't cut the coils on your springs unless you are on a really tight budget. You should do it right and get a set of lowering springs that were designed to operate at the lower ride height with a correct spring rate.
SP003
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 11-04-2011, 12:12 AM
ryany's Avatar
How far is these springs suppose to lower it?
Old 11-04-2011, 08:56 AM
BMR Tech2's Avatar
1.25-inch.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 11-04-2011, 09:52 AM
ryany's Avatar
Is that with the isolaters in there?
Old 11-04-2011, 09:54 AM
BMR Tech2's Avatar
Yes, 1.25 from the factory springs with the isolators in place.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Quick Reply: rear springs for drag racing.
