Are these heads screwed up?
I picked up an LQ9 from a guy who had already started "cleaning up" the heads. He took too much off in the bottom right corner of the intake runners and now there is a small ridge in the transition into the vertical wall of the intake runner. I will try to attach pictures. Would you guys use them? Don't really want to port them. He only touched the intake runners. Thanks.
I have the opportunity to pick up a set of 243 heads that have just been milled .010. I could pick those up but was worried about the CR being a little high. I know I could bleed some off with the right cam, but I don't want to have to turn a lot of rpms to make power. I also want to be able to run pump gas with absolutely no problems.
