Pontiac Firebird 1967-2002 - Exhaust on 3.8L V6
84/98firebird
11-04-2011, 09:42 PM
I just recently purchased a 1998 Firebird 3.8L V6 and the exhaust on it needs to be replaced from the cat-back. I was wondering what kind of exhaust i should get. I would like to get the deepest tone and rumble out of it that i can, even though it is only a V6. Any suggestions??? I was looking into the Flowmaster American Thunder Kit or the Magnaflow Kit with dual rear exits? Let me know what you think....Thanks
cemlsx
11-04-2011, 11:12 PM
NO , if you want a good sounding V6 , go for true duals ..
get a set of pacesetter headers , 2.5 universal H-pipe from summit , and 2 borla XR1 bullet mufflers .. maybe magnaflow mufflers if you want to keep the cost down ..
This is the best sounding setup on a V6 , and will be loud.
if you dont mind a loud exhaust , dump it by the axle , or run it through tail pipes if you want someting a bit more quiet ..
look on youtube and see for yourself , you wont regret it ..
84/98firebird
11-05-2011, 06:52 AM
Really don't want to put that much money in te car since it is only a v6
cemlsx
11-05-2011, 07:18 AM
ouch , in that case go for a TSP rumbler , It will have a nice rumble on idle , and it will be loud at WOT .. the catback systems designed for the V8 sound like shit and rasp too much ..
and if you have time , look fur used parts .. I`ve seen a set of true duals go for 400 with cats and everything ..
84/98firebird
11-05-2011, 09:07 AM
Where can I get a tsp rumbler and are they made for the v6 or the v8?
cemlsx
11-05-2011, 09:14 AM
look on texas speed , they make the rumbler ..
It fits both V6 and V8 cars , all you need is a 3` S-pipe with it , which can be found anywhere for cheap .. or just grab a 90 degree bend and cut it in half and weld it the other way around ..
84/98firebird
11-05-2011, 09:41 AM
Are you talking about the s-bend that comes off the cat?
cemlsx
11-05-2011, 09:45 AM
yes , stock one is 2.25" , but the rumbler is a 3" cat-back , so you`ll need to swap out the S-bend with a 3" one ..
84/98firebird
11-05-2011, 09:56 AM
Alright...i might just go home and order one tonight...thanks for your input
84/98firebird
11-05-2011, 10:11 AM
So even if I leave everything else stock...the rumbler kit should give it a nice rumble?
cemlsx
11-05-2011, 10:24 AM
well its never going to rumble like a V8 , but the rumbler system is loud , and does ahve a nice rumble to it on idle .. it does rasp much less then magnaflow or flowmaster too ..
this is the only vid I can remember of http://www.youtube.com/watch?v=D_PnTa6Dnnk
notice that he has Longtube headers so it will sound a bit better , but a rumbler on its own will make a huge difference compared to stock ..
84/98firebird
11-05-2011, 03:20 PM
I see on Texas speed's website they have the speed rumbler kits for the v6's and v8's.. I was wondering if they are the same thing. I see the on for the v6 says dynomax bullet mufflers and the v8 one says bullet style muffler...is there a difference?
cemlsx
11-05-2011, 05:11 PM
Last time I checked there was no difference , and I believe you had a choice of mufflers , but dynomax is the cheapest one and most commonly used one ..
Id say just grab a V6 one (even though they should all be the same) lol
and get a 3" s bend from summit or somewhere .. you should be all set :D
84/98firebird
11-05-2011, 05:34 PM
I'm wondering if the difference between the two is the location of the hangers... Do you think I could reduce the muffler down
to a 2.5" or 2.25", whichever
is stock, so it fits on the stock
s-pipe? When I look at it, i don't know how I could replace the s-pipe because I wouldn't know how to connect it to the cat
cemlsx
11-05-2011, 05:43 PM
just leave it as 3` for better sound and performance .. I have no idea about hangers but everyone has used the same system without any fitment problems , or modifications so I do believe they`re the same..
you could get a adapter to connect the S-pipe to the cat , or remove the cat , I believe the cat inlet is 3" but outlet is reduced to 2.25" ..
84/98firebird
11-06-2011, 08:58 AM
I've been looking for adpaters and i cant seem to find one...Do you know where i could get one? thanks
cemlsx
11-06-2011, 09:16 AM
Id recommend summit racing ..
Cooldude5231
11-06-2011, 11:57 AM
just get a stock t/a exhaust.
thatll be cheap and affective
Cooldude5231
11-06-2011, 11:59 AM
i actually have a set if youd be interested
z-maro
11-07-2011, 02:23 PM
x2 I had that on my old v6 (just the muffler actually) and I think it sounded pretty good.
cemlsx
11-07-2011, 03:11 PM
My current setup is a V8 cat back too , It does have a nice Idle , sounds nice cruising around and stuff , but its not really `loud` or anything ..
The best thing is that it doesnt rasp at all unlike most performance exhaust systems ..
Im still getting true duals before christmas though ..
lemons12
11-07-2011, 03:32 PM
Factory.
