Supercharged, or not?
I want to keep the present cam, TR224, & mildly ported stock heads. Rod bolts are ARP's.
Will a supercharger match up with this cam, and if so, which do you recommend?
Would a turbo be a safer bet?
I'm not sure that the cost of supercharging will be worth it when played against any HP increase.
UNDER PRESSURE MOD
You may like the cam, but it's not ideal for forced induction, especially if it's on a 112lsa. The investment in going to forced induction is substantial, and trying to base you decision based on the current camshaft is backwards. It's like buying a new home based on what wallpaper is in the guest bathroom.
My advice is figure out which type of forced induction you really want, then swap the camshaft to match that setup.
Look at the turbo thread From Tinkrd. He has a turbo without a turbo cam and made some serious numbers. I think there are some good blower or turbo cams out there, but there are also a lot of hype that makes you think you have to have that cam to make power. The cam you already have is somewhat small would probably work pretty well. I would figure out what you want to do blower wise and leave the cam in there. Then maybe later on switch to a FI cam.
LS1Tech Sponsor
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
The LSA on this cam is 114. From what I know (not too much!) about superchargers, the LSA should be less in order to obtain the greatest effect from a blower. So, in my case, would a 112 or less have been a better choice as opposed to the 114?
Thanks, Glenn
LS1Tech Sponsor
Basically, it is the other way around as the post above this states. Bob
__________________
FWIW, my cam is a very non-boost friendly cam. 231/234 .648/.598 111lsa. I didn't even have FI in mind when I did my cam swap, then came across a good deal on a D1 so it switched my path completely (for the better I might add.) but my car made 383 with cam only then the blower at ~5.5psi with a FMIC it made 571. So that's 188more horse. Not bad for stock 853's, and my cam.
