93 9 second LSX Coupe FS
Year: 1993
Make: Ford
Model: Mustang
Price: $6000
Mileage: 60000
Private or Dealer Listing: Private Listing
Location (State): ND
Color: White
Transmission: Automatic
Drivetrain: Rear Wheel Drive
CAR NEEDS TO BE PUT BACK TOGETHER AND THE PRICE REFLECTS THAT!
Everything From the strut tower forward has been removed in preperation for frame, radiator, and side curtain modifications for big turbo kit install. Car needs a new radiator, and I have the electric fans. I have the radiator support and smooth side curtains. Car stays in heated garage and has had the E85 removed and replaced with regular gas for the winter!
The car has all of the following parts installed:
93 Mustang Notch
Motor:
LQ4 rebuilt with ARP rod bolts
Custom Comp cam .620 lift
L92 heads with .650 valve springs
L92 Gm performance Single plane intake
Fuel
Holley 750dp with Proform main body for E-85
Aeromotive A1000 fuel pump and regulator
-10 feed fuel line
-8 return fuel line
Exhaust:
Kooks 1 7/8 long tube headers with a 3 1/2 collector
custom 3" X pipe
3" Dynomax Ultra Flo mufflers
Rearend:
8.8 with 3.73 gears and a Auburn posi
5 lug axle conversion
Suspension:
Adjustable Camber/Caster plates
Front coil over struts
50/50 Lakewoods shocks
MM adj. lower control arms
MM double adj. uppers
Aje k member and front control arms
Misc:
95 mustang brake upgrade
5 lug conversion
01 Cobra wheels powercoated black
Msd 6012 programable ingition
Taylor Plug wires
Fast E85 Dual Bank Wideband Controller
Extra set of mickey thompson Drag Radials with Draglite 3.5" fronts and 10" rears.
Autometer Gauges
Power Adder
250hp Capable Edelbrock nitrous kit
Th350 with a 36 element sprag, reverse manual valve body, pro-tree trans-brake and a 4200 stall convertor. This tranny was rebuilt in the middle of last year when I installed the new convertor.
Ran a 11.05 on motor with little tuning on drag radials and a 9.90 @ 136 on a 150 shot of spray. Very fun car to drive around town and to the track.
NEED TO SELL ASAP I AM A MONTH AWAY FROM TRANSFER MAKE ME AN OFFER! ASKING 6000.....
I have additonal pics upon request.
Last edited by Silver408; 11-21-2011 at 09:24 AM. Reason: Lower price, add detail, add pics
AJE k member
Control arms
Coil overs (? Don't know what brand)
Roll cage
Sumped factory gas tank
Aeromotive A1000
Ford 8.8 with tru-trac 3.73 gears
Anti roll bar (came off 7 second turbo car in Fargo ND)
TH350 with full manual VB and Pro Brake
Custom built 3600 stall with billet and anti balloon for nitrous apps
Fast dual wideband O2 sensors
15x10 and 15x3" drag lites with older Mickey's
17" cobra R's with brand new rear Mickey's
Car runs on E-85 and is a monster on the street. It runs 10.9's-11.2's on motor and 9.8-9.9 on 100
shot. I have clean title in hand and am looking for a quick sell. I have more in the motor setup than what I'm asking for the entire setup. I have receipts and detailed photos for all interested.
Control arms
Roll cage
Aeromotive A1000
