02 TA Koni SA`s with Spohn Delrin LCA`s ... Squeak?
Old 11-07-2011, 12:04 PM
Patsy57's Avatar
Default 02 TA Koni SA`s with Spohn Delrin LCA`s ... Squeak?
So I have a nasty squeak on the driver side rear, the squeak occurs when i hit bumps or push down on the back of the car. The shocks seem to be tight though and do not seem blown at all. Very Very stiff when pressing the back up and down. That being said its driving me nuts and I was wondering what everyone though it may be?
Old 11-07-2011, 06:51 PM
JD_AMG's Avatar
Did you grease the LCA's properly? (with a grease gun?)
What other suspension mods do you have? Did you move your exhaust around at all when installing mods? (loose exhaust can sound and feel like a suspension squeek).
Old 11-08-2011, 08:52 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
What he said. It's very important to grease any new suspension part thoroughly before it's installed.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 11-08-2011, 06:47 PM
Patsy57's Avatar
Yea I had them installed so I would assume they greased them but then again they may not have. I will go and use a greese gun and let you all know. Thx
Old 11-09-2011, 08:40 AM
BMR Tech2's Avatar
With the majority of shops, if you don't specify or request them to do it, they won't. Also be sure that you use a SYNTHETIC GREASE. Any petroleum based grease will eat away at the bushing.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 11-16-2011, 08:19 AM
Patsy57's Avatar
Everything is greased any other thoughts? I think it must be the left rear shock just not sure how to test.....
Old 11-16-2011, 08:41 AM
Shockwave179's Avatar
I have a similarly stiff suspension setup. Are you absolutely positive that the squeak isn't coming from inside the car?
I had a ridiculously annoying squeak and couldn't figure it out for the longest time. It turned out to be the rear seat making noise where it clicks in the upright position (metal to metal) because of the stiff suspension. Car never made that noise with the sloppy stock suspension.
Old 11-16-2011, 08:51 AM
BMR Tech2's Avatar
Did you end up swapping the shocks to the oposite side?
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 11-16-2011, 08:52 AM
BMR Tech2's Avatar
Indeed. The rear glass and rear panels tend to squeak a lot, when they do squeak!
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 11-16-2011, 09:50 AM
Patsy57's Avatar
I am not sure, but when I push down on the bumper on the outside it does squeak not as loud as when driving but it squeaks. Its also really stiff
Quick Reply: 02 TA Koni SA`s with Spohn Delrin LCA`s ... Squeak?
