Western Members CA, AZ, NV, UT, CO, NM, HI
Will 315 rub!?
Old 11-07-2011, 03:25 PM
saucymaro's Avatar
Default Will 315 rub!?
Hey guy looking to buy some tirrd today! Please please! Will 315 fit on my stock wheels on my 2001 z28 camaro? If not what do u fellas recommend thanks
Old 11-07-2011, 03:26 PM
saucymaro's Avatar
Sorry my rims are 17 inches please help! Thanks alot
02ws.sik's Avatar
Yep they sure will what type of rims though
Old 11-07-2011, 03:27 PM
02ws.sik's Avatar
17x? How wide are they and what is the off set
Old 11-07-2011, 03:37 PM
nomoneyz's Avatar
Fit safely on a stock 17" wheel. No.
Old 11-07-2011, 04:09 PM
02ws.sik's Avatar
If its stock which i think is 17x9 for ws6 rims. You need 10.5 or 11 inch.
02ws.sik's Avatar
Get some 275 draf radials.
Old 11-07-2011, 04:53 PM
mannyman84's Avatar
285 is max allowable with the 9.5 ws6 or SS wheels. U need 10.5 to 11 to fit 315's
Old 11-07-2011, 05:30 PM
saucymaro's Avatar
They are eagle wheels I bought the car like that. Soo 315s wont rub? Would it be safer to jus run 295?? Thanks guys
Old 11-07-2011, 05:34 PM
02ws.sik's Avatar
How wide are the rims?
Old 11-07-2011, 11:27 PM
saucymaro's Avatar
I went with some 275/40/17 just to be on the safe side thsnks for your help guys
Old 11-07-2011, 11:35 PM
henry172's Avatar
I have 315s on my 17x9.5in Z06 rims; they fit fine in the rear of my 97 TA. But they are nitto 555r, I have been told thay are the only 315s that will fit.
Old 11-08-2011, 01:12 AM
LS1Adam84's Avatar
if they are the eagles I believe they are then they are only 17x9, might even be 17x8.5. No 315's won't fit, well not correctly. you need at least a 10.5 in rim even for nittos, they recommend, at least last time I checked their site, at least 10.5" wide rim for 315 wide tire.
You can search and find out all you need on 315 wide tires, but to make it simple you need to bfh (big f***ing hammer) the inner wheel well to clear some spots and if your car is lowered you need to roll the fenders. Plus you need the correct width rim and correct offset.
Old 11-08-2011, 06:51 AM
02ws.sik's Avatar
[QUOTE=henry172;15597954]I have 315s on my 17x9.5in Z06 rims; they fit fine in the rear of my 97 TA. But they are nitto 555r, I have been told thay are the only 315s that will fit.[/QUOTE
555rs run small and i wouldn't keep those on if your making power
Old 11-08-2011, 03:03 PM
henry172's Avatar
^Yes I know the nitto 555r 315s are not the best dr's for traction, but with my little 340rwhp a4 lt1 they get the job done and I can get some decent street miles out of them.
Old 11-08-2011, 04:47 PM
Vette310's Avatar
315 will fit on a 10 inch rim and is still very safe. Just did an install on a 20x10 with a 315 has a mild positive stretch and is very daily drivable. Negative stretch is what you should be worried about.
Old 11-08-2011, 04:53 PM
tt383lt1's Avatar
on my 94 z i have 335 on a 17x11 vette rim with no rubbing. dont know the back space.
Old 11-08-2011, 08:14 PM
ConElite's Avatar
yeah your pushing it with a 315 on a 9.5" wheel. At least a 10" wide wheel. Puts stress on the sidewall and can cause a wobble effect when you corner hard. Not recommended.
I used to run 315's front and rear on my Trans Am. Run 315's on the rear no problem with a 17x11" on a 4" back space now.
I run 315 on a 11" wide wheel on our camaro too.
I would recommend an adjustable panhard bar and do a Hammer mod to the inner fender well. If your lowered an adjustable panhard is a must.
Old 11-09-2011, 06:53 AM
SteveC's Avatar
Location: Poway, Ca. where GOD and the sun always shines
Thumbs up
It is not the width of the rim that is the concern, as much as it is the "offset", any size rim (16,17,18, etc.) will rub above a 56mm offset.
I have 18x9.5 rims all around with 285x35xzr18 tires with a 48mm offset, no problems whatsoever.
With the correct offset you can go up to a 11" wide rim on the rear, I would not go any bigger than a 10" up front.
SteveC
Old 11-09-2011, 08:44 AM
ConElite's Avatar
SteveC
I run 11" wide wheels all the way around and daily drive my car. 295 tires up front with zero problems. Im sure my R&P hates it .
I believe its on a 50mm offset (If my calculations are correct). Its almost completely flush with the fender. 50mm-55mm and you will not experience any issues with rubbing
Did Roll rear fenders just for reassurance. Would not rub unless I hit the bump stops REALLY hard.
Quick Reply: Will 315 rub!?
