first ls1 comes with problems...
I recently bought a 2001 ss camaro that has a vortech supercharger on it.
the car smokes alot and has no power.
is it possible this is just cause of bad rings? starting next week i'm planning on doing a tear down of the engine but want to know what i'm getting myself into... I just bought this car and dont have alot of info on it. I called vortech and they didnt give me much to work with.
any input is greatly appreciated!
-kyle
-kyle
This is just a possibility, check your pcv valve and see if its stuck, mine was and caused my car to smoke like a doser. I thought it was blew all the hell because one day i just went outside and it smoked even at a idle. I took the pcv valve out and shook it and whiped it off and it completely stopped. Just something to try.
Well number 1 and 7 cyl have 20 psi the rest are 150-155 and 1 and 7 plugs are covered in oil. I'll do leak down later today... I really hope it's not a bad valve or valves
ah man. hope you got it at a good price. did this just recently happen right after you bought it???
kinda wonder if the previous owner knew something and didnt tell you...
I'd rather it be the bottom end vs something with the heads.... the car has 70k on it. I bought it in this condition but I was hoping I was gonna get away with honing the cylinders and putting new pistons rings and bearings in the bottom end and it would be fine. I'm guessing that the procharger's boost destroyed the rings and i'm not sure how many miles its been on the car...
why would I need forged pistons and rods? I read all the time that these bottom ends are good up to 1000 hp. I'm gonna pull the engine hone the cylinders and put new pistons bearings oil pump etc and then get it tuned asap. I'm thinking that the tune that was on it wasnt right. the plugs look pretty bad.
you guys dont think that the stock rods will hold the vortech charger? the issue i'm having now is most likely rings and or pistons from boost i'm assuming... pulled the trans today and will start on the engine tonight or tomorrow.
