LS4 Performance - Adding amplified subwoofer
I want to purchase a amplified subwoofer to give my 07 Impala SS factory Bose system some more bass. I have searched around :google: and looks like I have some options but Im looking for the easiest/cheapest way to do this. So I can tap right off the Bose amplifier in the trunk? Could I also purchase one of those PAC devices that will plug into the harness behind the factory HU to give me RCA connections? If I tap right off the amplifer what wires am I looking for? Any pictures of a LOC (line converter) installed? Thanks!
bignosecaveman
11-10-2011, 12:40 PM
I would like to do this as well. I have seen a post that talks about our bose amps having equalization build in to match the stock speakers thus limiting the deepest bass. Has anyone know of a harness available that would plug in before the amp, possibly a T harness ?
ghetto joe
11-10-2011, 02:16 PM
well i just added a subwoffer system to my monsoon system so i would guess it would be simular? i used a Audio control LC2i for the line out converter http://www.crutchfield.com/S-Bt0cZ3WjB5u/p_161LC2I/AudioControl-LC2i.html
and i used a P.I.E. Aux Input Adapter for ipod and xm www.crutchfield.com/S-3RjAJekzHvb/p_469GM12AX2/P-I-E-Aux-Input-Adapter-For-GM.html
Yes I have heard good things about the LC2i. Dont know if the Monsoon is similar to Bose or not but how/where did you connect the line out converter?
rm08gxp
11-11-2011, 10:10 AM
I dont get spending the 170$ to keep the factory? spend a little bit more and put a touch screen in? unless you have stock nav already?
Yeah that is a little much just to add a sub to the stock system. I like the factory look and I know there are cheaper LOC's out there.
ghetto joe
11-11-2011, 01:00 PM
you dont have to add the PIE input to add a subwoofer just the converter. at the time i purchased mine they had some $20 off coupons if you used payal so that helped and their are cheaper LOC i think walmart has em for ~$20. i also like the factory look along with using the amp for the internal speakers, also would have had to find an adapter or somesort so i could retain steering wheel controls
texasGXP08
11-11-2011, 03:02 PM
There are plenty of $20 alternatives. I have a scosche. Works awesome. Even if your are dead set set on that particular one, don't buy it from crutchfield, they are expensive.
yeah I know I dont need the aux adapter and that there are other LOC out there that are much less expensive. my real question was how/where do i connect the LOC to in the system?
ghetto joe
11-11-2011, 10:39 PM
i connected mine to my monsoon right before it went into the amplifier in the trunk
straitchev
05-05-2012, 07:03 PM
Resurrecting this thread. How DO you keep and a sub to the factory bose amp in the trunk?
bignosecaveman
05-06-2012, 01:58 PM
You can use the audiocontrol Lc2i and tap into the speaker wire for your factory 6x9 speakers. I did this recently and feed a Pioneer amp bridged mono for 800w and 2 dvc subs in ported box. You would be best to remove your rear seat and deck cover to have access to the wiring.
vroom_vroom
05-06-2012, 04:01 PM
just get a amp with a hi line input , and tap the wires to the rear speakers. no adapters required
V8ImpSS
05-06-2012, 08:01 PM
X2 you don't need the fancy LOC it won't do much for you. Id go with an Alpine MRX series amp which has a LOC built right in. That line of amps is about the best bang for the buck amp around while still getting a quality product.
crazyGXPguy
05-06-2012, 09:08 PM
i used the cheapest method lol because i am cheap, i bought the five dollar speaker wire with the rca connectors on each end at radio shack, cut off one end, spliced it, taketo one speaker in the rear and put positive on one side of speaker, negative on the other terminal, then connect the other end into your rca inputs on your amp, repeat other side, BOOOMIN for less than 10 bucks!:cool:
http://www.radioshack.com/product/index.jsp?productId=2102955
straitchev
05-06-2012, 09:27 PM
Thanks. Do you splice into the rear speakers before the factory amp or after?
crazyGXPguy
05-07-2012, 07:18 PM
I tapped right onto the speaker terminals, but if u can find which wires before amp, it would probably be safer on your amp although I've had mine hooked up for 3 months with no issues. I ran the remote wire into the fuse for the radio so ur amp will power on/off with radio. Ran ground to rear strut tower bolt. 4 gauge Power was ran alongside the remote, under rear seat , tucked under door channels on passenger side and ran through front door grommet up to battery. Cheers!
vroom_vroom
05-07-2012, 08:06 PM
would advise before the amp, you are adding ohms of resistance and will get less ass out of the back speakers if you tap on the the speakers directly (after the amp)
