wrong end links?
wrong end links?
bent both rear sway bar bolts. got these from autozone. they cant be right. it clanks and rattles on every bump because the sway bar moves so much. theres like 2-3 inches of play. the bolts look like the same size as the stock ones so i may just put the factory bushings back on.
any suggestions?
this is what i have. set up just like the picture. this is what autozone had in there computer for rear end links.
