Camaro 383 RMVB TH400
Year: 1997
Make: Chevrolet
Model: Camaro
Price: $9500
Mileage: 73000
Private or Dealer Listing: Private Listing
Location (State): OH
Color: Red
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Located in north west ohio delivery arrangments can be made
Car basics
1997 Camaro Z28 30th anniversary edition
73,xxx miles
Motor, Tranny, Rear all have less than 5k miles
Red with T tops
Weld draglites
Tinted tail lights and clear front turn signals
Hooker super competition long tube headers, 3" true dual dynomax exhaust also have borla single 3" currently installed
Deleted all emissions and deleted cruise control
Motor
383 LT4 with balanced eagle rotating assembly
LT4 conversion includes LT4 aluminum heads, 1.6 GM Performance rockers, timing gears and chain, and high flow intake
Heads have comp cams beehive springs with new retainers
Intake, valve covers and alternator have been powder coated
Alternator rebuilt
New optispark, coil, plug wires, plugs, ICM, water pump, hoses, battery, starter, oil pump, belt,
Aluminum crank hub rated for higher hp
Moroso cold air intake
36lb lucas injectors
Pcm tuning done by mad tuner
MSD ignition 6al with msd coil
58mm BBK throttle body, intake has been ported to 58mm also
Intake elbow
Throttle body bypass
Fuel line relocation
Drivetrain
Th400 with reverse manual valve body and a trans brake that is not hooked up
Deep aluminum Summit pan with drain plug
Locar dipstick
B & M Quicksilver ratchet shifter
10 Inch 3000 stall converter
UMI trans mount
Interior
Tan leather seats, power drivers seat
JL audio speakers with JL six channel amp and a 10" kicker cvr in a custom box and an Alpine deck
A pillar with 3 gauges, air fuel ratio, and fuel pressure, and tranny temp
Rear End
9 inch moser with true trac
3.73 gears with billet center section
powder coated fire dormant red
Suspension
Hotchicks control arms
AGX adjustable rear shocks
Hotchicks panhard bar
Kenny Brown welded sub frame connectors
This car is fast reliable and a very good condition car and is definatly worth the money, car is not perfect but there are only a few minor things
There is a lot more information that I have on this car please call with any questions 4196198715
Price is $9500 FIRM (price reflects a fast sale) if this is not sold shortly I will be trading it in
