Gears & Axles - junkyard rearend/axle id... read me
DEALERKIEL
11-11-2011, 07:39 AM
bought a 2000 ss 6 speed w/ 68000m last month and last night i was rotating tires when i noticed the telltale junkyard yellow paint on my rear axle. ugh. also noticed the sway bar end links were shiny/new. learned lesson next time will get car up in air before buying. anyway without taking off diff cover and counting ring/pinion can i get some feedback on what rpm people are at say at 70mph in 6th and where should i look on the axle for id numbers? no noise and rear is fine just bummed that its not original. in a few weeks i will be pulling diff cover to change fluid and inspect but for now any info would be apprieciated.
at work so i cant do a search, no time
hiltsy855
11-11-2011, 08:07 AM
I wouldn't be too disappointed. Most F-Bodies are going to have to absorb some amount heavy use / abuse, and sometimes they break. The factory rears in these cars are crap and are the weakest link in the drivetrain especially behind an M6. If it isn't making any noise I'd just change the fluid and drive it like you stole it. Mine has 3.42s (until I get my 8.8 installed) and I think I get about 1700 rpm at 70 mph.
litemup02
11-13-2011, 11:37 PM
Yeah no big deal.. 10 bolts are a dime a dozen and a ticking time bomb behind a 6 speed. Broke mine on street tires. Cant remember at 70...but i believe with the 3.42's i could run around 80-85 mph at 2k
BES Stroked Nova
11-14-2011, 01:01 AM
whats the difference if its had a rear end stuck in it? does the car run good? its hard to hurt a stock ls1... unless you just dont change oil.
metalmilitia606
11-14-2011, 01:04 AM
A 10 bolt is a 10 bolt really. As long as it is not making noise you'll be fine.
