New Products Showcase - Lingenfelter 5th Gen Camaro Drag Race Suspension
Jeff@LPE
11-11-2011, 02:49 PM
NOW AVAILABLE!
The Lingenfelter 5th Gen Camaro Drag Race Suspension kits were developed by LPE to help
improve the 60’ times and Ό mile performance of stock to heavily modified 2010-2012 Camaros.
The suspension package was developed using Lingenfelter’s LS9 supercharger equipped 2010
Camaro SS development vehicle. This 6 speed manual transmission vehicle is a powered by a
1250 rwhp 427 LSX engine with an LS9 supercharger and two stages of nitrous. The best quarter
mile to date on this 4200+ lbs vehicle is 8.99 seconds at 158 mph and the best 60’ to date is
1.304 seconds.
The shock valving is optimized for drag racing and the double adjustable front and rear shocks
allow a wide range of adjustments to work with almost any vehicle combination. The spring rates
have also been selected specifically for drag racing and are designed for a full weight vehicle.
In addition to being individually adjustable for both rebound and compression, the shocks are
adjustable for overall length, allowing ride height changes to be made without impacting spring
preload or overall shock travel.
The base package includes:
• Custom front and rear Lingenfelter by Pedders double adjustable drag racing shocks
• Custom front and rear Lingenfelter by Pedders drag racing coil springs
A more complete package that includes all of the major components used on the Lingenfelter
LS9 Camaro is also available. This package includes:
• LPE Gen 5 Camaro adjustable rear trailing arm, pair
• LPE Gen 5 Camaro adjustable rear forward tie rod, pair
• LPE Gen 5 Camaro adjustable rear stabilizer bar end link, pair
• 1” tubular rear adjustable anti-sway bar with brackets and bushings
• Differential bushing kit, fits stock or LPE 9.5” differential and features urethane side
mount bushings and a Delrin rear mount bushing
• Aluminum rear cradle bushings
• Underbody chassis brace
click the following links for more information
L500151410 (http://www.lingenfelter.com/mm5/merchant.mvc?Screen=PROD&Store_Code=LPE&Product_Code=L500151410&Category_Code=C396) Lingenfelter Camaro Drag Race Suspension Shock and Spring Kit only
L500161410 (http://www.lingenfelter.com/mm5/merchant.mvc?Screen=PROD&Store_Code=LPE&Product_Code=L500161410&Category_Code=C396) Lingenfelter Camaro Drag Race Suspension kit
http://www.lingenfelter.com/mm5/graphics/00000001/L500161410_900_318x350.jpg
http://www.lingenfelter.com/LPEforumfiles/picture.php?albumid=30&pictureid=595
Jeff@LPE
12-15-2011, 07:53 AM
There is still a few kits left that can make it in time for Christmas!
