Corvette Performance - best LS7 cam
I am sure this has been asked before. But what is the best streetable cam, for the most HP for the ZO6 LS7? I dont want to change the pistons or the injectors to do a cam install. I know, I will need to change the springs, retainers, and guides. So what do you guys like? I have heard the katech torqer 110, the black mamba ETC...... So Any help would be greatly appreciated.
redctsv
11-12-2011, 09:02 PM
What supporting mods will you be running? pump, e85 race gas? The stock injectors on pump with big cams and full boltons( fast 102/102 etc) are when they reach their limit( stock fuel pump is good to 650ish whp). Also please define what you mean by "streetable". Do you want to drive like stock or are you willing to give up some low rpm drivability for power? Also are you looking gobs of low end torque, high rpm power or a mix of both? I would contact either shop and see what they would recommend for you as they both have a large array of cam selctions.
CamaroSS621
11-23-2011, 10:30 AM
I was after a very streetable cam. andrew at csp made me a custom grind cam. give him a look. I did not change anything besides springs, retainers. no fly cutting or anything.
LSOHOLIC
11-24-2011, 12:24 PM
Give Geoff a call at EPS (Engine Power Systems 225-751-8500), I hear nothing but great stuff about his product. O...and I made roughly 1.7 hp per ci with a custom grind of his :D.
Thanks.......
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
