ARP Rod Bolts..what am I doing wrong?
Old 11-12-2011, 07:57 PM
Wicked69's Avatar
Default ARP Rod Bolts..what am I doing wrong?
I have a friend who is putting my new arp rod bolts in my 5.3 out of a 2003 suburban. He has done several big block builds in the past but this is his first LS type engine. He said to check to see what he needs to do because the arp rod bolts are just a tad longer than the stock and they don't just go into place.
When using the ARP rod bolts with the stock pistons/rods is there some "trick" per se that needs to be done to get them in there?
Thanks.
Old 11-12-2011, 09:58 PM
95ONE's Avatar
Did you leave the "Dowel pin bolt keepers" in there? - my term.. prob not the real name. Take them out.
Old 11-13-2011, 01:43 AM
tta656's Avatar
in the cap i think there are sleeves that need to be removed
Old 11-13-2011, 02:00 AM
BES Stroked Nova's Avatar
these are called ferrules. and they need to be removed. pretty much the stock rod bolt needs to be threaded back in at the top, and pull on the head of the bolt with a set of vise grips and you'll see the ferrule.
and I would be careful doing ARP's with a used engine without checking bearing clearances. Katech's should be used if not wanting to check clearances. Sometimes you get away with ARP's. sometimes you dont.
Old 11-13-2011, 02:25 AM
01ssreda4's Avatar
Yep, ferrules are in the way.
Old 11-13-2011, 04:25 AM
Footlead's Avatar
Default Arp
If you use the ARP rod bolts you need to resize the rods or probably will spin a bearing....I have seen it happen more than once. Katechs are said to work without any modifications.
Old 11-13-2011, 05:03 AM
Jontall's Avatar
Footlead is right... But a lot of people risk-it and get away with it, others spin bearings.
Old 11-13-2011, 09:52 AM
Wicked69's Avatar
Thanks. That was what I was looking for. Yes, it is the ferrules that are in there. Wasn't sure if you remove them or not.
Old 11-13-2011, 11:22 AM
KCS
Moderator
KCS's Avatar
Why are you putting rod bolts in a Suburban?
Old 11-13-2011, 11:51 AM
LSX Mechanic
Damian's Avatar
LOL. Exactly what I was wondering.
Katechs are the best for this type of application. I typically never recommend ARP rod bolts unless the engine and/or bearings are brand new.
Old 11-13-2011, 12:01 PM
s346k's Avatar
the motor is out of a burb.
i would NOT use arp bolts without replacing the bearings and resizing the rods. if you want to add aftermarket rod bolts without a rebuild, grab some katech rod bolts.
Old 11-13-2011, 01:37 PM
Wicked69's Avatar
The engine is out of a suburban. lol The rods are the cracked type. I didn't think you could resize these kinds. The bearings all look new and very low mileage on the engine.
Are you just using a press to get the ferrules out?
Old 11-13-2011, 03:47 PM
KCS
Moderator
KCS's Avatar
Ah ok, gotcha.
Yes you can resize these rods, it's just different than how you would resize a conventional Gen I SBC rod. It's best to at least check the housing bore when you put in the bolts.
I just tapped the bolt out of the cap with a punch and hammer. They're not in there very tight.
Old 11-13-2011, 04:38 PM
malibutwins's Avatar
Uhm....... whats wrong with a burb? My friend just had a 496 built for his 3 door burb. 600hp 630 ft lb pump gas motor
Old 11-13-2011, 05:17 PM
KCS
Moderator
KCS's Avatar
I didn't say there was anything wrong with putting them in a Suburban.
Old 11-13-2011, 05:38 PM
did everyone miss my post?? LOL
Quick Reply: ARP Rod Bolts..what am I doing wrong?
