Timing Chain Stock 5.3 twin turbo's
I just want to make sure I do this correctly. I am using the stock bottom end 5.3 to do a twin turbo, street/strip/E85 build. Since I am using new patriot gold dual valve springs, should I replace the stock timing chain or leave it? If replacing it what single HD chain should I replace it with. Trying to keep this on a budget but am using ARP bolts, opening the ring gap, new valve springs, and the XER 273 cam. Using that cam would it still be a stock replacement timing chain? Any opinions with part#'s welcome.
Thanks. I did search first but it seems the answer was just always HD timing chain. I was trying to find something a little more specific with a part # if possible.
Ls2 timing chain should work fine. Around $40.00 I got mine from Scoggin Dickey. From everything I have read I'm not convinced you have to open the ring gaps at all. I have run 15 psi on 93octane and have zero problems with the stock gaps. I seriously considered opening them while I had the heads off to change lifters but didn't see it as necessary. I would at least upgrade to LS7 lifters while you are in there. My oem lifters started making a lot of noise after putting patriot golds on, maybe bleeding pressure to fast from the higher seat pressure?
Thanks for the help gentlemen.
