Nitrous Oxide - Nitrous Gauges Question
karpetcm
11-13-2011, 03:10 PM
Can i pull off the nitrous bottle pressure gauge off my bottle and put it on a 2 pillar pod and mount it at the front were i can keep an eye on it from the drivers seat or do i need to buy another type of nitrous pressure gauge to do something like that. I need to mount my pressure gauge and a/f gauge on a 2 pillar pod in front so i can keep an eye on things.
mrdragster1970
11-13-2011, 04:19 PM
The gauge port on most bottles are NOT after the valve, so if you remove it you would need specialty fitting to do what you want.
I tap into the line for my dash gauge.
karpetcm
11-13-2011, 04:56 PM
so you bascially get a y fitting of some sort and then get a long hose take it to the front and buy a 2nd gauge to mount in the front as well as leave the gauge thats already on the bottle.
mrdragster1970
11-13-2011, 07:05 PM
Exactly.
On my bottles is a gauge that stays and I use for warming in the trailer.
At the line adapter is a port that some use for a dash gauge or computer, I use it for my computer.
At the firewall bulkhead fitting, I have a T-fitting, and tie in my gauge there.
That way I can never forget to turn on bottle, because the gauge is at zero, until I throw the 1/4 valve.
I would definitely never remove the bottle gauge, I would add an adapter.
You really need to know the pressure at all times, especially in the heat of summer!!
Good luck.
Sales2@Texas-speed
11-15-2011, 11:34 AM
Or you could run the single supply line into your engine compartment, Y it there with one going to the gauge in your pillar and the other to your solenoid. Then keep that gauge on your bottle. The bottle gauge will tell you the pressure inside the bottle with the valve closed, and the one on the dash will show the pressure in the bottle (equal to that in the line) with the valve opened.
Dirty Vegas
11-18-2011, 01:57 AM
Or get an electric gauge, and just have to run a couple wires.
mrdragster1970
11-19-2011, 07:16 AM
Just don't start an engine that had pressure on the noid.
They had a thread on another forum with engines that blew up when N2O leaked in to them.
That's why I always use a safety valve now, I learned my lesson after seeing those cars burn to the ground!!!
Beer99C5
11-19-2011, 07:42 PM
Not available any More but...two in one :)
http://www.retrorelics.net/jim/Boards/Corvette/TrickGa4.jpg
I have the bottle gauge, and then the lectric gauge is on a Mainline "Gauge fitting".
http://www.retrorelics.net/jim/Boards/Corvette/NANOMAY08Front.jpg
karpetcm
11-19-2011, 08:06 PM
nicccceeeee.
mrdragster1970
11-20-2011, 07:44 AM
I'm liking the idea of electric gauge??
I've never trusted elect gauges before, but this is 2011, maybe it's time to reconsider.
It would be much safer, and I would have less fittings & lines running all over the place??
KING Z28 HAWK
11-20-2011, 08:18 PM
anybody ever try glow shift performance electric gauges?
1quickTransAm
03-23-2012, 02:18 PM
i had a friend run glowshift gauge and I thought they were pretty nice, especially for the price. I plan on using a few for my upcoming nitrous build.
EngineBuilder59
04-02-2012, 02:16 AM
I dont see any problems with doing that as long as you get it all conneced securely.
