Early head studs on a 2006
Old 11-14-2011, 02:03 PM
Grendel's Avatar
Default Early head studs on a 2006
Is it possible to use early head studs on a 2006 block?
For the record, I have two sets of early heads.
Old 11-14-2011, 06:52 PM
S10xGN's Avatar
Well, some of them will fit, others will be waaaay too long...
Old 11-14-2011, 08:42 PM
Grendel's Avatar
I assume they could be cut down to fit?
Old 11-14-2011, 09:38 PM
Silver408z's Avatar
If you are cutting down to fit you will be cutting off threaded portions of the studs. Unless you need 2 sets of studs, sell the ones you got and get one set of the right ones for your car.
Old 11-15-2011, 08:14 AM
LS1-450's Avatar
Agreed.
Grendel, don't even mess w/ 'em. Reducing thread engagement by cutting is not something you want to do w/head studs. Use the correct length (short studs) & be done w/ it. Good-luck. To answer the specific question regarding whether long studs work on 06 blocks...not to my knowledge.
Old 11-15-2011, 09:50 AM
dodson55's Avatar
just use only the short studs you have from both sets and everything will work fine
Old 11-15-2011, 02:48 PM
01ssreda4's Avatar
No, they won't fit or work correctly. Get the right ones.
