1998 TA nitrous car complete all new !PICS!
Year: 1998
Make: Pontiac
Model: Trans Am
Price: $22000
Mileage: 1000
Private or Dealer Listing: Private Listing
Location (State): AL
Color: Blue
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
513-448-9224
Martin718fuq@yahoo.com
Car is the one in sig just new wheels
Transmission
Turbo 400 with trans brake, full reverse manual valve body
No passes just freshened up
Circle D nitrous converter 4400 stall no dumpasses
Sfi LS flex plate
B&M ratchet shifter for t400 reverse valve body and new cabledum
Trans cooler and stainless lines and fittingsdum
Chassis
Rear end is a 12 bolt with 3:73 full spool
Burkartt chassis drag anti roll bar
Subframe connectors
10 point cage
Qa1 SA front coil overs
DA afco rears
Burkartt pan hard bar
Burkartt tubular k member with tubular upper and lowers
Aero space front brakes
Burkartt radiator setup with miezer radiator mount water pump
All black AN fittings and coolant lines
Gz Motorsports race series vac pump
Dual NOS bottle mounts
Stand alone nitrous fuel tank with walbro 255
Racetronix in tank with hot-wire in stock fuel tank
Big stuff 3 ignition
Race pak dash
Billet specialties fronts and rears
Motor
dumComplete LS nitrous motor top to bottom
Canadian Performance 402ci LS2 shortblock built by Dave Diluca
Callies Compstar Crank
Callies Compstar Rods
Wiseco Nitrous pistons
Hellfire Rings
ARP 2000 rodbolts and ARP mainstuds
motor is built for a 400 shot of nitrous
Livernois Stage 3 L92 heads, milled to give motor an 11.1-1 compression
New GM rockers, both intake and exhaust
Cometic .040" head gaskets
L19 ARP headstuds (these were over $500 by themself)
Custom Comp cam specced out by Patrick G
Comp pushrods
LS7 lifters
Ford Racing 42# injectors
ASP underdrive pulley
Beck sheet metal intake
102mm TB
Beck plate on top of runners, set up for two stages
Fogger setup also
This intake was plumbed by nitrous outlet, has 8 solenoids, 3 stages, capable of insane hp on spray
Intake setup alone is $3500.00
Motor is 600plus crank hp and built for spray but was sprayed only once for a hit on Dyno
Motor has 5 1/4 test passes
25,000 FIRM
Haha thanks for the free bump with the awesome post, if you can't spell or speak English maybe you should invest your money in school instead of a race car don't get butt hurt about the post people put about your junk ESPECIALLY if you can't provide the answers they ask
Not worried about selling, if a buyer is seriously interested the can get pictures emailed to them like a few already have. Like stated in the very first thread I CANNOT upload from an iPad and I am currently out of state working. But hey thanks for another bump
