Recommend me some parts
My 2000 Z28 was in an accident and now I'm in the process of buying the parts back to fix it. I've got a hood, grille, and headlights to replace with some aftermarket pieces. I had a SS hood so I'm pretty set on going back with it unless I find something I like better. What do you guys think I should go back with for the lights, hood, and grille? Thanks. The car is white with a SS rear spoiler to by the way.
http://www.dashzracing.com/98-02-che...98-pbc-rf.html
id put these lights in it. and get an ultra z hood, then of course a 6le grille
Copy & Paste Moderator
Instead get the Sonar projector headlights or put OEM HID projectors into a stock or aftermarket set of headlights.
Check out the Lighting FAQ for more info on that (and some recent threads in this section).
https://ls1tech.com/forums/appearance-detailing/710357-lighting-faq.html
Looks like that website does have the Sonar headlights as well:
http://www.dashzracing.com/98-02-che...m98-hl-bk.html
However, it says they use 9005 bulbs for the low beam. Except they don't. Unless these are different/custom version, the Sonar projectors use a H1 bulb for the low beam.
If you look on ebay, you can find them cheaper with HID kit.
