76mm on a 5.3, but which 76mm?
Old 11-15-2011, 02:38 PM
streetknight2's Avatar
Default 76mm on a 5.3, but which 76mm?
Seen a lot of builds around here saying they have a 5.3 with a single 76mm, but which turbo is everyone using, or what are the options at least?
TIA
Old 11-15-2011, 02:56 PM
killernoodle's Avatar
TC76 is the most compact, good bang for the buck. It is smaller physically, so it should spool pretty quickly on a 5.3 and it is pretty easy to find a place to stick it. The on3 76mm is essentially a t76 with a F1-65 turbine, so it should max at around 700 whp and have good spool on a stock 5.3. They are pretty cheap too.
Old 11-15-2011, 06:08 PM
SPRAYED 01's Avatar
Why not tc78. Same size physically. I have a barely used one for $750 shipped.
Old 11-15-2011, 06:30 PM
Is it a .96 ar?
Old 11-15-2011, 06:35 PM
SPRAYED 01's Avatar
Yes. Il also throw in an air filter and the dp. Its stainless.
Old 11-16-2011, 12:13 AM
skinnies's Avatar
If you want sub 700rwhp go with a tc76(or 78) if you want more than that go with the precision billet 76.
Old 11-16-2011, 07:15 AM
I guess I'm like most people, I want as much as I can get lol. This will be going on a pretty much stock 5.3 (planning on just fasteners, valve springs and cam)
I'll be running a Turbo 350 trans with whatever stall speed converter I need. I do want to run an exhaust system on the car and don't want just a dump since it's a street car, so down pipe size may be a factor.
Basically would the Precision HPS76 be overkill for my application? The car weighs 3400lbs with driver. I'm wanting mid to low 10's.
Old 11-16-2011, 12:25 PM
Black_Phantom's Avatar
p7675
Quick Reply: 76mm on a 5.3, but which 76mm?
