Valve Float
Old 11-15-2011, 02:50 PM
neals98's Avatar
Default Valve Float
Ok i have a Stock Cube LS1(5.7) carb set up it has
Vic jr intake
Trickflow 225 heads
Yella Tera Rockers
23x/23X comp cam
Gm lifters (GM Performace Part #12499225)
Problem is that if i shift anywere about 6200 RPM's the car slows down. Its like i can feel the power fall off. Anyone had any problems like this or know what to look at first. Heads, Cam, and lifters are only about 3 months old.
Old 11-21-2011, 01:31 PM
neals98's Avatar
What is the min and max preload on the GM lifters Part #12499225?
Old 11-21-2011, 02:01 PM
senor_camaro's Avatar
i would say check your valve springs and see if they are rated for your cam. you might need stronger valve springs to keep your valves closed.
Old 11-21-2011, 07:39 PM
SweetS10V8's Avatar
Throw on stock rockers and try again......
Old 11-21-2011, 07:58 PM
crainholio's Avatar
Vic jr intake
Trickflow 225 heads
Yella Tera Rockers
23x/23X comp cam
What jets are you running in the secondaries?
Old 11-21-2011, 10:07 PM
ls1 1990 VN's Avatar
Change gear faster & back on the gas ....What valve springs are you running?
Old 11-22-2011, 11:43 AM
neals98's Avatar
Thats one of the things i am looking at now. Mine are 142# closed and 375 open.
I have one more race this year and thats what i am going to do. After this race im pulling motor to freshin it up and check everything.
Its a new pro systems carb with 76/86 jets.
LOL thats what i have been doing. Its the springs that came on the heads. I dont think they have enough open pressure for my cam with the YT rockers.
Old 11-22-2011, 01:19 PM
NVR_SPDS's Avatar
Do you know what lobes the cam is ground on?
Old 11-22-2011, 01:46 PM
you should check the cam manufacturer specs for what kind of valve spring to run on the cam. easy fix that should get your power on!!!!!
