Notices
WTB 6.0 Lq4 or Lq9 block and crank with main caps
Old 11-17-2011, 07:26 AM
Boost-box's Avatar
Default WTB 6.0 Lq4 or Lq9 block and crank with main caps
I am looking for a 6.0 LQ4 or LQ9 bare block, with main caps and crank. I want something in good condition, no junk PLEASE! EMail me at strelkom@gmail.com with what you have, I am located in Stafford VA 22556 and will travel anywhere in a 300-400 mile radus. thanks!
Old 11-18-2011, 07:23 AM
Boost-box's Avatar
anyone?
Old 11-18-2011, 10:11 AM
sic7camaro's Avatar
I have a l92 block and crank $1050+ the ride
Old 11-20-2011, 10:34 AM
Boost-box's Avatar
ill pass thanks.
looking to really spend no mpore than $500.
Old 11-23-2011, 08:21 AM
Boost-box's Avatar
bump it
Old 11-24-2011, 01:03 AM
98silvermaro's Avatar
I got a LQ9 block with the main caps and a LQ9 crank $500 plus the ride
Old 11-24-2011, 08:17 PM
Ws6Dnero's Avatar
pm sent
Old 11-27-2011, 11:20 AM
Boost-box's Avatar
bump, I would really prefer to stay in a 300-400 mile radius... my zip is 22556
Old 12-15-2011, 08:24 AM
bww3588's Avatar
I have the 6.0 crank...in Ohio tho.
Old 12-21-2011, 09:55 AM
tsnow678's Avatar
I am having a 408 built as we speak and soon as it is finished I will have a shortblock LQ4 for sale. The shortblock would consist of, stock LQ4 pistons, new rings, stock rods, new ARP rod bolts, standard crank with new Clevite bearings, mains, rods, cam bearings were all replaced. New LS2 timing chain, cam is a regrind, 236/242 @ .050" with .580"/.590" lift on a 112 LSA. All new GM torque to yeild bolts in the bottom end. I am unsure if the front, rear, valley covers go yet. I may or may not let the lifters go. All this depends on what I can find from now till the stroker is complete. For the shortblock I will take $650 with no covers or lifters. You can look at my build in my sig and check the engine out. I am having a low vacuum issue with my current setup with my enormous L92 heads so It was either rebuild what I had or move forward. I chose the more expensive path and moved forward. The engine is currently in my car and is running if you wanted to stop by and take a spin. I live in Germanton, NC so I am not sure if thats within your driving requirements or not.
Old 12-21-2011, 09:58 AM
tsnow678's Avatar
267 miles from Stafford,VA to Germanton, NC!!!
Old 12-22-2011, 01:35 AM
thirdgengta350's Avatar
PM sent.
Old 12-22-2011, 09:38 PM
454navyss's Avatar
i have an lq9 block and crank in the garage....fresh out of the machine shop
Old 12-26-2011, 03:13 PM
RezinTexas's Avatar
I'll send you the crank for $110 including shipping.
https://ls1tech.com/forums/parts-cla...-part-out.html
Quick Reply: WTB 6.0 Lq4 or Lq9 block and crank with main caps
