Pontiac GTO 2004-2006 The Modern Goat
where to find these gauges??
Old 11-17-2011, 08:42 PM
Nastynotch's Avatar
Default where to find these gauges??
Can find only a picture. I need to find where to buy these.
Old 11-17-2011, 08:53 PM
jit11375's Avatar
http://www.ebay.com/itm/SCSS-GTO-GAT...#ht_784wt_1127
pretty close i'd say...but not exactly the same
Old 11-18-2011, 12:59 AM
05raptorle's Avatar
speedhut
Old 11-18-2011, 03:42 AM
Jontall's Avatar
They are Speedhut gauges, but for a GTO, you get them at SCSS: http://www.teamscss.com/Pontiac_GTO_Shop.htm
Old 11-18-2011, 06:43 AM
Nastynotch's Avatar
Thanks guys!
Old 11-18-2011, 11:21 AM
nick.celis's Avatar
I love those guages! Im going to get some as well!! Thanks for the link
Old 11-18-2011, 11:39 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
They are indeed SpeedHut gauges. You can order them directly from SpeedHut with the GTO logos and all - which is what SCSS does - or you can customize it with your own logos, messages, or whatever you want.
The quality is...deeecent. They aren't the most reliable gauges in the world and the gauges look kinda lame when you look at them up close because they print the backgrounds with a lo-res image, or at least my gauges are like that.
They match the interior PERFECTLY, though.
Here they are on my car.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 11-18-2011, 01:07 PM
massillongoat's Avatar
those are sick...I"ll be calling speed hut
Old 11-18-2011, 06:05 PM
gconnoyer's Avatar
Originally Posted by BMR Tech2
Did you have to do anything to get those to work? Or is it plug and play like on the factory harness.
I'm looking to do the exact same setup.
Old 11-18-2011, 07:18 PM
nick.celis's Avatar
^^^ i was wondering the same thing! i definatley want a set that match the speedo guage etc.
Old 11-19-2011, 12:46 AM
PontiacPOWA's Avatar
those are really sweet looking! i just couldn't justify spending 500 bucks for 2 gauges...
Old 11-19-2011, 01:43 AM
quickkris2006's Avatar
Yea thats amount of money does suck but thats the price for having stuff match
Old 11-19-2011, 03:41 PM
OVRPWRD's Avatar
I have the SCSS gauges in mine. They LOOK awesome and factory but not real accurate. They have a tendency to fluctuate with the draw on the battery.(oil press and volt goes up/down when lights are turned on, sometimes the oil will go over 100, then back to normal)Pretty common from what I have read. Mine were not plug and play... had to wire them, but came with directions. I got mine used off of another GTO forum for $275.
Old 11-21-2011, 08:52 AM
BMR Tech2's Avatar
To install the replacement panel with the gauge package, you need to clearance the plastic (all hidden under the panel) a bit to get them to sit flush like mine is the photo. Just use a dremel. My gauges are wired up through an "oil filter sandwich adapter" and not plugged into the gauge wires under the panel. I only think some '05 and '06 cars have the wire harness under the panel, not all cars got it. And I also think you have to buy specific gauges from JHP for them to work.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Quick Reply: where to find these gauges??
