How far would you take a stock crank?
In for more responses. But FWIW, my engine builder (LME) said I would be ok for up to 1000rwhp but it would be slightly risky, and that he wouldnt recommend I run the car constantly down the track at that power level.
My engine is an iron block 370 forged rods and pistons, but stock crank.
before there was any aftermarket support on these engines people like Harlan were running 347 setups with stock cranks down the track at over 1200 rwhp consistently without issues....
Interesting you and Los both have had issues with the stock crank. Even more interesting you both are running a T4 PT88. It's probably pure coincidence but I wonder if excessive exhaust back pressure is causing issues.
I have a question for guys having issues with the stock crank. What damper are you running?
No one has ever had a "crank" fail. Tolerances, detonation, oil pressure and many other issues can hurt a crank like the few posts above. But a stock uncut/unmolested crank will not fail. I've seen as high as 1500rwhp on stock cranks.
