Bone stock 02 ta a4 heads cam help?
Old 11-19-2011, 04:53 AM
MikesTA2002's Avatar
Default Bone stock 02 ta a4 heads cam help?
hey guys new to the board i have an 02 ta a4 bone stock i have the fast toys lid on the way so far, gonna do some kook LTs 2inch down to the 3in collector and 373 gears... heads cam help? what would be a decent combo with my a4 and 373s?? thanks
Old 11-19-2011, 04:54 AM
with a 3100 stall and being streetable... \
Old 11-19-2011, 05:00 AM
last thing...i want to be around the 440+ rwhp range
Old 11-19-2011, 05:57 AM
ULTIMATEORANGESS's Avatar
Smile
trick flow and MAST have some badass heads but $$$$$$$$$.
you can go bigger than a 3100 stall and be very streetable.
Old 11-19-2011, 06:13 AM
garygnu's Avatar
vengeance racing or TSP have head/cam combos for a good price.like stated above get a bigger stall.
Old 11-19-2011, 10:12 AM
LS1Tech Administrator
RPM WS6's Avatar
Received 1,460 Likes on 1,053 Posts
I'd get a 3600-4000 stall, and keep the stock gears. But that's just me.
Old 11-19-2011, 06:29 PM
thanks guys! ill check them all out, off question but do you guys know what wheels are on that black ta vfn wsq hood???
http://www.vfnfiberglass.com/9301firebird.htm
Old 11-19-2011, 06:44 PM
zracer323's Avatar
2" headers are way overkill on a 346. Most go with 1-3/4", but 1-7/8" primaries would work pretty well with heads/cam
Old 11-20-2011, 06:35 AM
99WS-6T/A's Avatar
those are MIRO 111 wheel.
Old 11-20-2011, 06:54 AM
alexus6798's Avatar
^What he said^too much header
Old 11-23-2011, 06:52 PM
camaroboy14's Avatar
At mikes TA . Get a the LTs, gears and a 4k stall ... That should hold you off for a little IMO ...
Old 11-23-2011, 07:54 PM
A.R. Shale Targa's Avatar
You can send your factory heads to Advanced Inductions and have them CNC
ported, plus a custom cam from EPS will get you to your target power level.
Old 11-26-2011, 10:25 PM
Xaviarrahl's Avatar
Anyone get to that power level on stock castings (NA)?
Old 11-27-2011, 01:16 AM
doubleD_white_t/a's Avatar
Have you considered nitrous? A 150 would be safe and make it a lot easier to reach your goal
Old 11-27-2011, 09:01 PM
SSLSXLQ9L92's Avatar
Your car is a 02 so you probably have the good 241 heads. I would send them out to be ported by a reputable local porter. They will usually order you a custom grind cam at there specs. This is only if you can afford the extra down time on your ride.
