10 Second Club - Typical H/C Junk
View Full Version : Typical H/C Junk
Detroitmuscle
11-19-2011, 09:44 AM
Its winter time so might as well let the cat out of the bag, nothing special anyways but I was pleased with how it ran for what it is. Drove it to and from the track. Basic rundown
LS2 shortblock, stock rods, pistons, crank
235/243 .621”/.624” 110LSA +2
ETP 5.3 heads
LS6 intake
Bolt-ons
stock catback with cutout
4L60E with a SS4000
UMI suspension with stock shocks/springs
8.8 rear with 3.73s and a 28" radial
3650+lbs
http://i5.photobucket.com/albums/y153/rodneysk8/photo1.jpg
j_pyrdol
11-19-2011, 02:08 PM
Nice numbers... any plans for the winter???
Detroitmuscle
11-19-2011, 08:51 PM
No plans for winter other than tying up some loose ends and changing fluids.
deerslayinrednek
11-19-2011, 10:21 PM
ever been on a dyno? I'm curious what the HP difference was between the stock cat-back and the cutout
Detroitmuscle
11-20-2011, 08:18 AM
yep its a big difference here is the graph between open and closed.
http://i5.photobucket.com/albums/y153/rodneysk8/photo2.jpg
Detroitmuscle
12-20-2011, 08:49 AM
forgot to post a pic of the car.
http://miketpg.smugmug.com/Cars/Milan-Dragway-NO-ET-Sept-17th/i-MCKdm9h/0/L/TPG0865-copy-L.jpg
06X6spdGTO
12-28-2011, 07:53 PM
did you have to do any flycutting to fit that cam with the 5.3 heads?? What compression are you running??
Detroitmuscle
01-03-2012, 09:46 AM
I did not have to flycut, the compression should be around 10.8:1
BOBS99SS
01-03-2012, 10:00 AM
nice ride man, much props for running a great time, that pic looks killer
06X6spdGTO
01-03-2012, 05:58 PM
what CC are the ETP 5.3 Heads?? running on the stock GM MLS head gasket??
Detroitmuscle
01-04-2012, 07:48 AM
64cc chambers and yes a stock MLS gasket.
Mike Morris
01-05-2012, 09:16 AM
Nice job!
Detroitmuscle
01-05-2012, 12:50 PM
Nice job!
thank you.
moge11
01-06-2012, 02:29 AM
Thats a Nasty Ride you got there! NICE PASS!
Detroitmuscle
01-09-2012, 02:15 PM
thank you, I only hope to go faster in the future.
moge11
01-09-2012, 11:33 PM
Youre welcome... Im sure you will knock a few tenths off with some tweaks..
02sleeperz28
01-09-2012, 11:50 PM
Nice! Any video?
Detroitmuscle
01-10-2012, 06:22 AM
here is a vid of a 10.91 pass.
http://youtu.be/PVzg5H4Rdb8
FASHOOTER
01-11-2012, 05:59 AM
I remember watching that race, nice win!
Detroitmuscle
01-11-2012, 11:01 AM
thanks. we ran it back after that race and Larry sprayed the second time around but I still got him thanks to him having converter issues.
02sleeperz28
01-11-2012, 10:40 PM
Nice! Thanks for sharing.
WSsic66
01-14-2012, 10:34 AM
Good job
LS1rob00
01-14-2012, 11:46 PM
Nice! Car looks mean in the launch pic.
nnag
01-17-2012, 12:03 PM
congrats on the runs, very nice times. I have the same gearing and converter as you, but with a 26" hoosier. I thought that the bigger tire would slow you down in that combo, am I way off here?
Detroitmuscle
01-18-2012, 06:32 AM
I don't think that mindset is off, I actually was worried about that same thing but I don't believe it had much effect. Here is a pass I made the year before on a 26" tire. Mind you this was not a perfect pass but a clean one nonetheless
1.55 60'
7.10 1/8
96.28 mph
11.19 1/4
119.61 mph
The only changes I made from then until now were that I went to a bigger FTP lid with an 85mm MAF, added a u/d pulley, and removed the a/c. The car gained 20rwhp and as you can see it trapped 3.39mph higher even with the taller tire.
shortdog
01-19-2012, 06:26 PM
For your setup and weight, your car is running pretty decent. 364ci correct?
I remember we both had problems with poor ETs several years ago, but we finally got it figured out.
Detroitmuscle
01-20-2012, 06:24 AM
yes I do remember that, you live and you learn for sure. You are correct the motor is a 364ci LS2 stock bottom end aside from rod bolts I'm hoping I can do some small things and get it running just a tad better while I finish collecting turbo parts.
LSxPwrDZ
01-21-2012, 12:20 AM
Def nice running car! You have a very similar cam that I have in my Formula. Ours is a LSL lobe 235/243 112+2. Ours being lower compression on stock 241 LS1 heads is really hurting this camshaft I believe. It made 396rwhp and has run a best of 11.7@116 so far but the stock tranny gave in on that 11.7 pass. 4k Circle D stall aided in that I'm sure haha.
Congrats on the 10's! That's flying in a stock bottom end full weight car.
Detroitmuscle
01-23-2012, 07:45 AM
thank you very much it has taken me a little longer to get to this point but I am pretty happy with the car thus far. Really makes me want to buy a fast intake, drop some weight, and see how fast I can go like this.
LSxPwrDZ
01-23-2012, 09:22 PM
Your mods list is just about identical to the list of stuff I either already have and are about to do. I am doing a set of 799 TEA St2 heads on the original LS1 from my 02 Formula and have the cam I listed above with a Circle D 4K stall. I'm hoping that I can get somewhere close to the bottom 11's with the setup and maybe some high 10's with a Fast90/92/102 intake setup.
Keep up the good work!
speedtigger
01-23-2012, 09:30 PM
Your car is running hard at that weight. You are where I want to be. I am about where you were in the time slip you posted from last year. I am looking for all the little things to get 3725 lbs closer to 10s.
Detroitmuscle
01-24-2012, 08:30 AM
I did very minor mods from then until now, just went over everything a second time and caught a few little problems. One of which was a dragging set of rear brakes, car tapped the limiter on the 1-2 shift as well, and removed some weight. Couldn't believe it gained 20hp from a lid and u/d pulley so that was a bonus.
z28241
01-26-2012, 06:56 PM
Very nice..what headers are u running?
Detroitmuscle
01-26-2012, 07:57 PM
Just some 1 3/4 pacesetters.
z28241
01-26-2012, 08:32 PM
u going to stay w/pacesetters?
Detroitmuscle
01-27-2012, 06:45 AM
at this point I don't see me spending any more money on the motor, I have some turbo stuff I'm putting together slowly so for now I may just finish off the suspension.
z28241
01-29-2012, 12:58 AM
okay yep, missed the post of going turbo...
c0ncEpT
02-01-2012, 08:46 AM
Looks like the dirtiest car at the track. Good job Jeff!
Detroitmuscle
02-02-2012, 07:13 AM
it very well could have been, that day didn't necessarily start out how I had planned wish I could have done a few things before leaving. Here is a go pro vid of an 11.19 pass so this isn't a meaningless post.
http://youtu.be/ettqi0muQFg
