PRW, PQ series Aluminum Shaft Mount Rocker Arm System-3334611, who's running it?
I'm current running stock rockers until I can find some good roller rocker to run in place of the YT ultralites I removed, since I had one break the other day.
Anyway after a few hrs of searching I came across the PRW, PS's #3334611, so are they any good, who's running them?
I see them on Ebay for $420, retail is $650.
BTW, does anybody know if they make these with steel rockers, or is it only w/Aluminum rockers?
Thanks!
Thanks!
The CompCams rockers are a 1.75:1 ratio, that would increase my valve lift from .614" intake an .617" exhaust lift, to .632" intake an .635" exhaust lift. My valve springs can handle the lift, but I don't know if I want to increase the lift that much.
Do you know are the Comp rockers adjustable? I'd rather not screw with an adjustable rocker, but instead set the lifter preload with a proper lenght pushrod.
I don't see "adjustable" in the description but want to be sure.
