what size AN is the factory power steering hose on a LQ4? can i cut it and...
i was wondering what size the factory power steering hose is in AN(2002 LQ4) - im thinking about cutting it to the desired length and using a hose end like this then a adapter from Xan to inverted flare into my factory gearbox
would this work?
would this work?
Honestly as was said the best route is get one made. Even if you found a close size fitting, AN fittings require a pretty specific ID/OD to make a positive seal. I think you'd just be asking for a high pressure fluid spray
