Notices
Need everything for rebuilding a rolling 98 z
Old 11-19-2011, 10:28 PM
LSXBlazer's Avatar
Default Need everything for rebuilding a rolling 98 z
Hey guys just bought me a 98 roller z that will be getting a 370LS, turbo and some other goodies however i pretty much need everything
heres a list of what all im looking for
Engine/drivetrain:
2000 and up ecu
late model coils with harnesses
80# injectors
fuel system
narrowed rear axle dana 60, ford 9 inch??
intercooler
edelbrock L92 port intake
intake elbow
throttle body 90mm+
wastegate
BOV
Suspension:
pretty much anything aftermarket let me know what you got
torque arm relocation kit
adjustable arms
panhard
sway bars
coil overs
wheels/tires ?? what u got
Body:
possibly anything to convert from tan interior to ebony
SS hood possibly a damaged one
stock headlights may trade halos that i have for stocks
front facia
headlight supports
If you have any of these things pm me with what you have and how much you want for it
Thanks
Old 11-20-2011, 06:50 AM
O1ws6's Avatar
https://ls1tech.com/forums/parts-cla...at-system.html
Old 11-20-2011, 08:46 AM
URLOSN's Avatar
Fuel system
https://ls1tech.com/forums/showthrea...ce+fuel+system
Old 11-20-2011, 10:09 AM
jwcarguy's Avatar
Default 98 ECU / PCM and exhaust manifolds
Blazer,
I have the correct 98' ecm for that car #16238212 $100 shipped
I also have the correct "steel tube" factory exhaust manifolds with the egr tubes, valves. etc The early f-bodies uesd the steel tube "double wall" exhaust manifolds, rather than the later cast iron
most people like the steel tube, due to easier to modify / weld on
These are dry rustfree So. Cal., from a car that only had 500 miles on it!! and has been inside stored since 2000
Let me know if interested, I have ads / pics in the classifieds
Thanks, Jeff
Old 11-20-2011, 10:30 AM
black and pink z28's Avatar
I have a fresh t56 its has a level 2 biuld in it from the gear box
Old 11-20-2011, 06:21 PM
LSXBlazer's Avatar
I already have a transmission thanks but I do need a turbo 350 swap cross member and driveshaft
Old 11-20-2011, 06:28 PM
LSXBlazer's Avatar
Old 11-21-2011, 11:34 AM
LSXBlazer's Avatar
Bump!
Old 11-21-2011, 12:08 PM
URLOSN's Avatar
I have a PST aluminum driveshaft for a th350 to an 8.8 rear might need a front yoke, the splines are slightly twisted. Worked fine when I took it out. 200$ shipped
Old 11-21-2011, 09:05 PM
jwcarguy's Avatar
Don't need the ecu from my earlier post??
Jeff
Old 11-22-2011, 12:01 PM
snipes's Avatar
PM sent.
Old 11-22-2011, 02:25 PM
CaMaRo67RS355's Avatar
PM if you are interested-Eibach race springs with airbag, m6 trq arm relo kit, metco lca's, adjustable panhard, track setup weld alumastar fronts and centerline telstar rears with tires
Old 11-23-2011, 10:20 AM
andrew69_04's Avatar
ive got a set of eibach sportline lowering springs and a complete automatic harness and ecm from a 2002 camaro ls1 if your interested
Old 11-23-2011, 05:17 PM
LT1Formula007's Avatar
A buddy of mine has a completely PORTED L92 victor style intake with a FAST 4150 TB setup on it, And a DBW TB and all the actuators/linkage to make it work. Also has a blow thru carb hat for it, and etc. He's asking $1k for all of it. he's going back to a Ported LS3 intake because his car Lost alot of torque by going this route, and with his current setup It's just not working out for him. This has only a couple hundred miles on it. PM me if interested. I can get you pics.
**It's currently on a 2011 Camaro SS.
James
**I (Myself) have A LS1 F Body Oil Pan setup for $225 shipped. Everything is there except for the windage tray. But Those are about $20-$30 from the dealer.
lmk if interested...
Old 12-01-2011, 10:08 PM
LSXBlazer's Avatar
bump
i have ac system now
most of interior
i have a harness
still looking for PCM 2000 and up
need carpet, headliner, and visors in ebony
lmk
Old 12-04-2011, 11:03 AM
jwcarguy's Avatar
do you need the factory exhaust manifolds for that 98' ?
Old 12-04-2011, 11:13 AM
projektnitemare13's Avatar
I've got a set of 80 injectors, let me know if you need em.
Old 12-04-2011, 11:27 AM
LSXBlazer's Avatar
Doing a turbo setup no on the manifolds and how much on the injectors?
Old 12-04-2011, 04:09 PM
Blue441LS7's Avatar
Default Rear susp
I have an anti roll bar, qa1's lower control arms and torque arm for sale. PM me if interested.
Old 12-04-2011, 06:46 PM
4u 2 nv's Avatar
I have some headlight support brackets. Send me a PM with a pic so i can tell for sure which ones you want. I ahve both sides.
