Lnc-002 ???
Old 11-19-2011, 10:33 PM
redriver racing's Avatar
Default Lnc-002 ???
99 camaro!! First i dont have the 2-step hooked up. What wire on the clutch sensor do i use to hook it it up? Would like to set my nitrous up to come in when clutch is released!!! It's set up now on a wot switch and would like to leave that way. Is there anyway to do this where when 2-step goes off nitrous comes in?
Old 11-19-2011, 10:36 PM
VinnieV02TA's Avatar
i am not sure if the lnc 002 can do that but i know progressive controllers can
Old 11-19-2011, 11:00 PM
I have the mini progressive on there just not hooked up but how would i wire that up. Do u just delay the progressive or u hook it up to the 2-step?
Fbodyjunkie06's Avatar
As the guy above said I know progressive have inputs for 5v references that when the transbrake or clutch releases it sends an input to the WOT switch which tells it, it can activate at the set rpm window. If the 2 step has a 5v input you should be able to splice off the WOT switch wire that activates the shot of nitrous to the input on the 2 step so when the 2 step kicks off it allows the WOT switch to activate and spray.
if that sounds weird or if I have something backwards someone with more knowledge can chime in, but I think that's right.
Old 11-19-2011, 11:04 PM
yea i dont know the wiring part of it but i have a few friend that have it set up like that. One of my friends have the line lock,trans brake,nitrous all on one switch
Old 11-19-2011, 11:26 PM
Maybe someone else has the same set up and can help!! Thank's for the help!!
