Painting an LS1?
Old 11-20-2011, 12:51 PM
Geoff55's Avatar
Default Painting an LS1?
Anybody paint their LS1 or other aluminum block engine?
How did you prep it and what paint did you use?
Please post pictures if you've got 'em.
Thanks
Old 11-20-2011, 12:52 PM
xpndbl3's Avatar
scuffed it with a green 3M scrub pad, then degreased it, washed it and painted it with VHT gloss black engine enamel.
Old 11-20-2011, 03:18 PM
t72ss402's Avatar
Pressure washed the motor. And painted it with high temp engine paint aluminum and then clear high temp.
Used same paint on the accessories and painted all pulleys with black high temp and clear high temp.
Tim
Attached Thumbnails Painting an LS1?-imag0190.jpg   Painting an LS1?-imag0205.jpg
Old 11-21-2011, 10:46 AM
Geoff55's Avatar
Man, Those engines look great!
Thanks
Old 11-21-2011, 11:23 AM
-TheBandit-'s Avatar
From my build thread:
Originally Posted by -TheBandit-
This weekend I decided to tackle cleaning up and painting the engine. First I needed to seal everything up to prevent water from getting in.
I removed the valve covers and removed the rocker arms. This puts all the valves in a closed position, which should help prevent any unwanted liquids from getting in.
Next I stuffed the ports with towels and used a quality (Scotch brand) duct tape to mask off all the ports and sensors.
Then I laid a tarp out in my driveway, rolled the engine out, and went to town with a few cans of engine degreaser, a scrub brush and the garden hose. These pictures were taken at various stages of cleaning.
On the last few clean & rinse cycles, I used Eagle One Mag Cleaner in a spray bottle from my local autoparts store. This is an etching cleaner that contains a few different acids. It did an incredible job of restoring the aluminum to a more uniform appearance. Once everything was degreased and thoroughly rinsed, I put a few fans out to dry things off.
Old 11-21-2011, 11:24 AM
And continued:
Next I used some painters tape and masked off the heads, waterpump ports, and cam position sensor boss. Most of the other connectors were already masked off with duct tape from earlier. For the waterpump ports, I put tape on the old gaskets and used some bolts to hold them in place.
Finally, I laid on several coats of Duplicolor engine enamel. I used this on my old small block and it lasted 12 years and still looked good when I pulled the engine.
These pictures were taken as the paint was still drying, so it looks kinda splotchy but you get the idea.
Later this evening after rolling her back in the garage, I set the intake back on top and snapped these photos. Overall I'm pleased with how this cleaned up and I'm very happy with the painted valve cover, painted timing cover look. I wish it wasn't going to get cluttered up later with accessories, wires, etc.
Before:
After:
Old 11-21-2011, 01:56 PM
Geoff55's Avatar
Great post!
I was thinking about that etching aluminum wheel cleaner to prepare the surface, looks like it works well.
Thanks!
Old 11-21-2011, 05:09 PM
Rocketrod's Avatar
Click the link in my signature to my build thread and look at post #6.
Old 11-22-2011, 10:16 AM
RenoReno2's Avatar
POR makes engine paint you brush on as well. Looks pretty good
Old 11-22-2011, 11:09 AM
Pocket's Avatar
Tractor paint is brush on as well and is extremely durable
Old 11-22-2011, 01:29 PM
sciff5's Avatar
I could see John Deere green being used with yellow accents on a show car
Old 11-23-2011, 05:32 PM
john j oliver's Avatar
Default Excellent
One word "Excellent write up". Or is that three
Old 11-23-2011, 10:57 PM
Pocket's Avatar
They sell black too, which is what I use extensively
Old 11-24-2011, 11:38 AM
NemeSS's Avatar
I clean the engine with any needs to remove scale,grease and dirt. Usually pressure wash with purple power. Finish by hand and steel brushes. Usually just paint bright aluminum silver or silver hammertone.
Quick Reply: Painting an LS1?
