Dyno Guesses & Bench Racing Forum - Ls3 2000 corvette dyno numbers what will it run?
bigboy2
11-20-2011, 06:52 PM
I have a 418 ls3 that made 456rwhp and 427ft torque!!! Through a a4 with a yanks 3200ss converter unlocked!!! It also has stock 315 rear gear set,and full bolt on as well .I thought it was pretty low my self ,I wanted to see what my motor made.. The dyno operator said it could use a little more timing and that it was lean down low.. I have cnc ported ls3 heads and will have the new tsp aftermarket ls3 heads so I can see the difference in power . The motor runs strong and raced a few low 11 second cars and walk around them on street tires.. I have a set of nitto's nt05r coming for next year.. Just curious to see what you guys think...
bigboy2
11-23-2011, 09:10 AM
Will this thing run in the 10's with a good set of tires? That's what I'm hoping for on horsepower and will be adding the bottle next year!!!! I'm also adding the new prc 250 ls3 heads to see what kind of power she will make but they are going on early next week and then the dyno!!!!
30th t/a
11-23-2011, 11:10 AM
Id be disappointed with those numbers
bigboy2
11-23-2011, 12:36 PM
well I am and going to try and get it fixed.. will know next week after my other heads are put on and retune....
jetaws6
11-23-2011, 12:39 PM
what cam you running?
3.8redbird
11-23-2011, 12:41 PM
why the unlocked converter?
bigboy2
11-23-2011, 04:19 PM
The guy said thats the way you run it on the track so there was no reason to lock it up!!! he said thats it just to show a higher number...so i said ok den....
bigboy2
12-03-2011, 04:42 PM
Just put new heads on it and and now it just made 510rwhp and 476ftq!!!! un locked, so hoping with the new power we should be able to get er in the 10's.... My drag radials came in yesterday but it won't be untill next year to see what she will do....
Prorac1
12-03-2011, 05:51 PM
What heads did you have, and what heads did you replace them with? Congrats, Eric L
3.8redbird
12-03-2011, 10:12 PM
60hp from heads? Thats crazy. Was anything wrong with the ls3s?
bigboy2
12-03-2011, 10:26 PM
Not that i know of!!! the new head design is just awesome , 13* compared to 15*heads. I was able to mill for alittle more compression without effecting the flow numbers i assume.But the smaller runners helped pick up velocity which I believe helped in the added horsepower... it was 54hp but thanks for the extra ..lol :cool:
A.R. Shale Targa
12-04-2011, 06:12 PM
Nice gain !!!!!! Even on an engine that large it still pays to match the runner
volume for proper port velocity :D
bigboy2
12-05-2011, 08:06 AM
They where either tsp or scogging dickey cnc ls3 heads to the new prc 250 ls3 heads from tsp!!!! I bought them from a guy named Jason on this site and they where new with light weight valves casting numbers where the 821's.... They worked good but these worked better!!!!!:burn:
bigboy2
12-24-2011, 08:09 PM
Well I'm putting a gz vacuum pump , halltech killer bee2 and a set of stainless works 1 7/8 headers.. What kind of gains can be had? I'm thinking around 25 rwhp or so??? I want to get it dynod again but will wait till after Christmas just want to get an idea of what to expect...:cool:
bigboy2
01-14-2012, 12:38 PM
well did get it dynod and put down 537rwhp unlocked and 554 lock!!! not bad i guess....
bigboy2
01-31-2012, 07:53 PM
Just ordered a nitrous 102 plate kit, controller and stand alone fuel tank.. We should be able pick up about decent horsepower!!!!!!
A.R. Shale Targa
01-31-2012, 10:17 PM
Are you sure 700 will be enough ????? :eek2:
bigboy2
02-02-2012, 10:15 PM
Probably not but you know how those horsepower numbers go!!!!!! We always won't more!!!!!!lol:drive:
