IAT harness
Yeah, I didn't think there was a sub harness for that. I was pretty sure you just had to find the wires that come from the PCM for the IAT and wire it in yourself (which is what I'm doing).
Moderator
My IAT is relocated using a Digi-Key thermistor for the
sensor and a couple feet of scrap wire. If you want OE
type equipment then any Firebird / Camaro in a boneyard
has your IAT pigtail. Most likely Casper's has something
too, or you could just get the Metri-Pak connector from
WayTek (body, pins, grommets all ala carte with minimum
quantities).
quantities).
Is this what you're needing...
http://www.thunderracing.com/shop-by...rness_985.html
You want to go from the combo maf/iat sensor to just an IAT sensor, correct? You can simply cut off the maf pigtail if you are staying SD or just zip tie it away.
Ok I didn't think I could use that harness because I'm going to take the MAF out completely and just use th IAT in a piece of pipe in place of the MAF. I just want it to look good not some hack job
