Well I finally got some pics of my 370 and its ready to go in
Old 11-20-2011, 08:40 PM
stngtamr29's Avatar
Default Well I finally got some pics of my 370 and its ready to go in
Hey guys its been awhile since Ive been on here but as you can see Ive been busy Ive got my Heintz Racing Engine and it wont be long now we should be able to dyno it in a week or so. This is what we are putting together: 370ci LS2 block with main stud girdle, single oringed, 1/2 ARP main studs 10.7cr, Billet Lunati crank and rods, JE pistons, Mahle rings, 215 AFR heads (341 cfm @ 600) xceldyne valves, LS9 head gaskets, ported LS2 intake. Also you can see the F1A Procharger on the front of it and we will be maxing it out so if anyone wants to give a educated guess on the power would be great it will be run through a RPM level 7 4l65, 3600 vigi, 9" moser, Kooks 1 7/8 and Kooks 3" true duals. Thaks jeff
Attached Thumbnails Well I finally got some pics of my 370 and its ready to go in-motor4.jpg   Well I finally got some pics of my 370 and its ready to go in-motor3.jpg   Well I finally got some pics of my 370 and its ready to go in-motor2.jpg   Well I finally got some pics of my 370 and its ready to go in-motor1.jpg
Old 11-21-2011, 09:37 PM
9sectruck's Avatar
10.7comp. and 22-25psi is alot of cylinder pressure,
any pics of the girdle?
I think it will make 1070 on the tire dyno jet
how did you get a 370? you get the block re-sleeved
I am doing damn near the same build... 1/2 main studs with a girdle, 365inch only 9.5:1 maxed out f1r looking to make 1100 on the tire
Old 11-21-2011, 10:21 PM
stngtamr29's Avatar
I dont have any pics of the girdle but Ill get you the name of tomorrow but its a really nice piece its billet aluminum and about 1/2 thick and it bolts to the main studs it cost about 500.00 and we didnt resleeve the block so I dont really know how they got 370 out of it. I would really love to make 1000 rwhp also Im putting a 66mm wastegate and an AMS 1000 boost controller on it so I can tame it down alittle on the street. thanks jeff
Old 11-22-2011, 06:14 AM
1fast bird's Avatar
I think the reason he asked if the block was resleeved is because most don't bore the ls2 that much. Anything above .010 over could make the sleeves too thin. That isn't a good thing if you are going to put a lot of boost to it.
Old 11-22-2011, 02:05 PM
9sectruck's Avatar
^^^ exactly what i was thinking alot of pressure on a thin sleeve,
OP your build is right at the same **** im doing I have a44mm waste gate already piped in my set up to controll boost on the street.
keep me posted on this!! I dont know if my car will get done over this winter it will probably take until middle spring before mine refires
Old 11-22-2011, 04:00 PM
brians91formula's Avatar
that compression matched with that amount of boost doesn't seem like a good idea does it? You will probably have to run a lot of meth and race gas to prevent detonation.
I'm going with a similar build but I was planning 9.5:1 compression.
Old 11-22-2011, 06:08 PM
stngtamr29's Avatar
Alright I found out that ERL makes the girdle but I used a Moroso pump and pan and we had to do alot of fab work on the pickup to make it work and I also found out that the engine is really closer to a 365 sorry about that and I will be spraying meth with this setup and I talked to the guys at the engine shop and they assured me that the sleeves were still thick enough to handle the pressure the we will see also I will let you know what we make as soon as we get her together. thanks jeff
Old 11-22-2011, 06:21 PM
MillsMotorvation's Avatar
Nice setup!
Old 11-22-2011, 06:23 PM
stngtamr29's Avatar
Originally Posted by MillsMotorvation
Nice setup!
Thanks its been a long time since we started. jeff
Old 11-23-2011, 08:00 AM
9sectruck's Avatar
a 365 is just a .005 over bore, so the sleeves are good to go, are you sure the compression is going to be that high for the amount of boost you are going to put in it?
Old 11-23-2011, 09:08 AM
usually if compression is high you will need less boost to make your dyno number. Although race gas, meth, or E85 will probably be needed to prevent detonation.
I'm really unsure how well your compression ratio will work with high boost. Has anyone else done a high compression, high boost build and had good luck with it?
Old 11-23-2011, 11:31 AM
westtexasbuff's Avatar
With E85 he should be fine... 20lbs might be pushing it though.
Old 11-23-2011, 11:41 AM
redtan's Avatar
Lot of money spent and then throwing it all together with the ls2 intake?
Otherwise nice build, interested to see how a maxxed out F1A does with that compression.
Old 11-23-2011, 12:03 PM
Fireball's Avatar
we had nearly that compression with double the boost he's targeting...on race fuel of course
of course when things go wrong....big time failure happens
Old 11-23-2011, 02:06 PM
V68Sweep's Avatar
Nice and clean so far!
Old 11-23-2011, 07:04 PM
9sectruck's Avatar
so what is the time frame to firing this thing?
that girdle looks sweet
Old 11-23-2011, 07:34 PM
Cam72aro's Avatar
Honestly if it didn't make 1000 to the wheels I would use it as a boat anchor.
Old 11-23-2011, 10:22 PM
stngtamr29's Avatar
I know the cr is 10.7 to1 and were going to push it if it blows we'll build another one. Ill be running race gas and meth when im on high boost but I should be ok with pump gas on no more than 7lbs on low boost while its on the street. jeff
Old 11-23-2011, 10:25 PM
stngtamr29's Avatar
Yeah I have a FAST to put on it but I thought the ls2 looked better. jeff
Old 11-23-2011, 10:29 PM
stngtamr29's Avatar
Thanks I owe it all to the guys at Heintz Racing they definately have there act together. jeff
Quick Reply: Well I finally got some pics of my 370 and its ready to go in
