Dynamometer Results & Comparisons - Tested Holley Hi-Ram LS3 intake vs Stock LS3, 45 rwhp gain on stock LS3 heads
CalSpeedPerformance
11-21-2011, 04:27 PM
We have been very happy with these Holley Hi-Ram intake manifolds so far in our testing.
Vehicle/Combo:
1962 Nova LSx conversion -
408" Stroker, Stock LS3 cylinder heads, 11.25:1 compression
247/259, .624/.624 @ 114 LSA LSL/LSR lobe camshaft
CalSpeed custom built 2" Primary headers /w 3.5" Collectors, open headers
Powerglide /w 5600 rpmm stall 8" converter (Goes 5200 on transbrake with both intakes)
Tubbed 9" Rear-end /w 33" x 14" slicks
Tested with factory LS3 Intake manifold /w Edelbrock 90mm throttle body
Peak power @ 6000 rpm - 460 rwhp (Power fell to 420 rwhp by 6800 rpm and much worse above that on other pulls)
Swapped to Holley Hi-Ram intake with same throttle body 90mm
Peak power @ 6300 rpm - 480 rwhp BUT held powerband to 465 rwhp @ 6800
Right at 45 rwhp more at 6800 rpm and we plan to shift the car 6800-7000 at the track so hoping for 3-4 tenths at the track vs LS3 intake.
We are going to be testing again on the same comparison / combination with a set of Stg 3 CNC WCCH heads in a GTO /w lockup 4l60e trans next month. Results will be posted when available.
Dyno sheet:
http://i711.photobucket.com/albums/ww120/calspeed/Dyno/TedNoveLS3vsHiRam.jpg
http://i711.photobucket.com/albums/ww120/calspeed/Dyno/IMG_1260.jpg
http://i711.photobucket.com/albums/ww120/calspeed/Dyno/IMG_1160.jpg
Mike@Diablosport
11-21-2011, 04:30 PM
Wow, thats pretty impressive, great results.
Looks like there was no measurable loss down low on this application too...any feedback on drivability?
Sales2@Texas-speed
11-21-2011, 04:37 PM
Cool test, Jim! Did you make any pulls that show the low RPM stuff (under 5K rpm)? I'd be eager to see those number as much or more than those peak numbers!
slowride
11-21-2011, 06:59 PM
Check the stall, I don't think he can get lower rpm numbers.
1989GTA
11-21-2011, 07:03 PM
Darn good numbers taking the high stall torque converter into consideration.
CalSpeedPerformance
11-21-2011, 07:22 PM
Car flashes to what you see in the graph (non-lockup 5600 stall on the transbrake), no way of making pulls at lower RPM etc.
Next car we test on, we will lock converter and pull from about 2500 rpm up.
Tainted
11-21-2011, 09:25 PM
So would this be beneficial for people Ohh say a g8 with the l76 with a mid sized cam and head work? With supporting mods of course.
Or is this really for people with bigger cubes and top end cars?
bigmandengo
11-21-2011, 09:41 PM
How tall is this intake compared to the truck intakes? Do you have a picture from the side, showing the height of the intake?
AINT SKEERED
11-21-2011, 11:58 PM
I'm curious as to what et the car runs as is? I'm thinking about doing a 408 for my 64 nova@ 2600 rw
Nitroused383
11-22-2011, 05:08 AM
Thank you very much for posting results! Have you guys ever tested the pro flow intake? How does it compare if you have, doesn't seem anyone has posted back to back results.
82cetuner
11-22-2011, 08:51 AM
looks like theres no chance of this fitting under any car that came stock with a ls3 or even ls1 for that matter LOL
would love to put one under my ws6 trans am
CalSpeedPerformance
11-22-2011, 08:42 PM
To anyone asking questions on whether it would work better for their combination: Until you or someone dynos your exact combo, then its all hypothetical. I wouldnt take anyones word for any guess until its been tested.
Pro-flo isnt offered with LS3 based ports as far as i know, so no way to compare the two.
slowlsx
11-22-2011, 09:23 PM
Stupid that they don't make this for cathedral port :(
chriswtx
11-29-2011, 09:18 PM
looking forward to more test of this intake, thought it would keep pulling higher in the rpms.
HAHA I 1
11-29-2011, 09:40 PM
What hood do you use? I am ordering one of these for my 443 in the 67 wagon. It has a standard 2" steel cowl hood, so I am curious. I have measured, but would love to hear real feedback.
AINT SKEERED
11-30-2011, 12:20 AM
Nice collection of chevy II's .
CalSpeedPerformance
11-30-2011, 01:01 AM
I believe this hood would fit with a stock hood. The scoop on it doesnt provide any needed clearance and there is no cowl at the front where the highest point is (above the throttle body)
NemeSS
11-30-2011, 10:32 AM
Any word of cathedral port versions eventually?
HighspeedLean
11-30-2011, 10:55 AM
Jim, do you have any feedback on carb'ed version of this manifold?
I bet the blank top machined for a dominator would work just right for my deal...
1bigcam
12-26-2011, 03:13 PM
Any new info on this ?
a98ws6
12-26-2011, 04:46 PM
Ive read cathedral pory version should be out by late jan.
1sickz28
12-27-2011, 12:40 AM
if only this would clear a vette's hood!
a98ws6
01-23-2012, 10:33 AM
Cal Speed, did you ever test this on the low rpm lock up car you were going to test?
NemeSS
01-27-2012, 10:55 AM
:corn:
tonyturbo42
03-02-2012, 05:29 PM
http://bangshift.com/blog/holley-unveil-s-new-ultra-hp-dominator-and-cathedral-port-hi-ram.html
GIGAPUNK
08-22-2012, 09:17 PM
Did that lock-up'd trans test below 5000 rpm ever happen?
