95 z28 ls swap ?'s
95 z28 ls swap ?'s
Is it very complicated to do the LS swap into these cars with a th 350 or 400 trans? This is going to be a strip car only because it's not registered and it's gutted beyond repair... Or should I just put in a gen 1 sbc and be done??? If I need to change mounts and bunch of other stuff I can't afford. This is an EXTREME budget car!!!!
Well budget is small because I don't want to drop a ton of money at once. This is a secondary project so it will be an extra cash kinda thing. I would like to get motor,tranny,gears for under 2k. I have a guy that can set gear pack up, I can build the tranny and a guy says he can get me a motor for cheap. After building my last project it's not the major stuff I'm concerned with its the smaller things. Aluminum for interior,seat,belts,guages, mounts for everything..etc..
LS1Tech Sponsor
You should be able to do motor, trans and gears for under $2k depending on how fast you want to go and how long you want it to last.
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
