whf happned here? log inside
When i got water on my o2 connections i had a similar problem like a bad o2 sensor. You can see the shortterm fuel trims skyrocket with out any 02 voltage change which shows a nonresponsive o2 sensor. This is exactally what happened on my car and i dryed out the connections and made them more weather tight and it fixed it.
I would personally check o2 connections and if all checks out replace sensor. Im still a NOOB at reading these logs but thats my thoughts
I attached a log of when it happened to me if you would like to compare.
