98 z28 ls2,tfs225,th400,M 9" camaro
Year: 1998
Make: Chevrolet
Model: Camaro
Price: $10500
Mileage: 165000
Private or Dealer Listing: Private Listing
Location (State): FL
Color: Red
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Year: 1998
Make: Chevrolet
Model: Camaro
Price: $10.5k firm
Mileage: 165000
Color: Red
1998 Camaro Z28, t-tops. The car is in good condition.
Stock LS2 shortblock
ARP rod bolts
Trick Flow cnc'd 225's 59cc chamber
VA speed spec'd cam 232/238
PAC 675 lift springs
Caddy lifters
Comp push rods
Yella Terra ultra lites
Edelbrock Vic Jr
FAST 4150 throttle body
AED throttle cable and bracket
TSP 1 7/8 long tubes
3" duals w/18" bullets, V bands
DRIVETRAIN/SUSPENSION
Yank lock up TH400
Yank 4000 LU converter w/ARP bolts
B&M trans cooler
TCI flywheel w/ARP bolts
PST 4" aluminum driveshaft w/strange yoke
Moser 9", 4.10, pro spool, alum pinion support, 35 spline, back brace, powder coated black, narrowed 6" total, 5/8 studs.
QA1 single adj coilovers rear
BMR adj phb
BMR lca's
Madman torque arm
Wolfe anti roll bar
QA1 double adj coilovers front
EVERYTHING ELSE
10pt chromoly cage w/rocker bars
RCI harnesse
Corbeau seats
Sparco steering wheel
0.090 aluminum battery box/mount
Moroso push/pull
Weld Alumastars 15x10 6"bs rear, 15x3.5 2.25bs front.
Mickey Thompson 275/60/15 drag radials
Stock 1998 pcm w/speed density tune.
All wiring, fuse boxed, pcm, etc removed from engine bay.
No half assed parts were used on this car...
