Wtb oem fasteners !!!!!!!!!
i bought just a disassembled long block in pieces,now im needing the bolts,nuts,etc to put everything back together,someone make me a package deal on the following:
front ,rear cover bolts
windage tray nuts
front accessory drive hardware minus power steering pump pieces
starter bolts
oil pan bolts
bolts to attach the sensors to the throttle body(TPS and IAC)
and im prob. forgetting stuff,all this is for FBODY LS1 and i know i can go to the hardware store and get alot of it but thats a huge PIA to go in and have to know exactly what to buy
windage tray nuts
starter bolts
oil pan bolts
UPDATE:
have the oil pan,front and rear cover bolts on the way,still need:
coolant crossover attaching bolts
small screws to attach IAC and TPS to intake
possibly the water pump attach. hardware
bolts to attach both the pulleys
AC compressor attach. bolts, and prob. more i cant think of rt now
I would'nt buy them at the hardware store ,,,,,,,,,they don't have some of those mentioned and what they do have has different heads . Go to a junk yard or hopefully someone here can help You out . I have quite a few spares but mostly just the 8mm ones , I don't have the belt pulley bolts or the starter bolts I might have some of the fr accessory bolts but it would b a few days until I could get out there and figure out what You need/ what I have .
