What exhaust manifold for a 65 chevelle
Will a pair of 2010-11 Chevy Camaro SS LS3/L99 V8 Stock Exhaust Manifolds work on the 65 chevelle, I was looking on Ebay they have a pair off a 2010-11 Chevy Camaro SS LS3.
from the pictures I have seen of them... it looks like it should work.. as they are rear exit like the 4th gens...
On the 99 F-body drive side.. yeah. it gets close.. I just welded it shut and drilled and welded a new bunt about 90* inborad and they work ok after that. (but I later went with Headers anyway).
I have the 2010 Camaro manifolds bolted up to my motor right now which is going in a 67 Lemans. I have not tried to drop it in yet but it looks like I will have to grind a little off of the outside of the manifold flanges to clear the frame. I am a little doubtfull because of the way the manifolds point straight down and not back at an angle but we will see. im also curious if the 98-02 long tube f body headers will work on a 64-67 A body.
I am looking at the 2010 Camaro manifolds to. let me know if they clear the frame THANKS
Fbody manifolds work, may have to grind the flange on passenger a bit. Also i heard 08 + truck manis work. Heres some reading for u on my tests for headers
https://ls1tech.com/forums/conversio...ment-test.html
