dorifto83
11-22-2011, 10:43 PM
Edson
Contact thru PM or post
Title is clean ready to go.Up for sale is my 99 camaro z28 car had 101.5k miles on it, this car has been maintained by me, Castrol european blend oil every 2500 miles, I already have another car so I don't need trades. . Car has factory alarm, ttops that don't leak. Also removed outside door moulding to make it look more cleaner, the body is in good shape but has a couple parking lot dings, the passenger side panel under door has a dent in it, driver's side seat bolster has a hole from wear and tear and front right speaker was blown so I yanked it out. It is a 6 speed ls1 camaro, it has traction control, abs, t tops, power everything, cold ac, fogs. Corbeau LG1 wide driver/passenger seat. 6 Liter Eater front splitter. Custom tsx retrofitted into stock headlights with whistler mods. 5k Hids, and 4300k fog lights. Monster Level 2 clutch, new flywheel, new pressure plate, slave cylinder. Tick performance Master cylinder. LPP coated long tubes, LPP ORY, stock exhaust. Corvette o2 sensors (for longer pigtail for long tubes), eliminated 2nd set of o2 sensors. Replaced starter back in june. NGK spark plugs, MSD wires. A.I.R. and egr removed. SLP intake with cold air ram installed with k/n filter. Turn one power steering pump. Water pump, new thermostat 180*, changed radiator to LT1 for better cooling. Fuel filter changed late last year, changed all four brakes and rotors, fronts are crossed drilled and slotted. Driver's side window motor replaced. Car has a canned tune by FROST from ls1tech removing speed limiter, changing fuel and air maps and no CEL for air system, also tuned out 2nd set of o2 sensors. Optima red top battery, car had Monsoon stereo (still have stock radio as well.) Z06 replica rims with Hankook radials 245/45/17 up front 275/40/17 in the rear. The car needs speakers since they blew, and the wheel and pinion bearings need to be changed, rear end cover was removed and there was no metal shavings, and it does not affect driveability. I no longer drive the car as much since I have an infant and its a pain to put the car seat in there, any questions don't hesitate to ask. No trades, no paypal or shipping, those scam emails will be ignored.
Boston acoustics 746 4x6 component deck lid speakers.
Car has state inspection from july, if you live in a county that has emissions you will need to change the off road y to a catted y pipe, otherwise it will not pass.
Edson
http://i173.photobucket.com/albums/w59/b18c1delsol93/camaro/10863_1195134751611_1025702154_30534899_8305149_n. jpg
http://i173.photobucket.com/albums/w59/b18c1delsol93/camaro/10863_1195134791612_1025702154_30534900_6485693_n. jpg
http://i173.photobucket.com/albums/w59/b18c1delsol93/camaro/12-1E6EBCC3-160375-960.jpg
http://i173.photobucket.com/albums/w59/b18c1delsol93/camaro/12-1CB9E424-157046-960.jpg
http://i173.photobucket.com/albums/w59/b18c1delsol93/camaro/IMAG0276.jpg
http://i173.photobucket.com/albums/w59/b18c1delsol93/camaro/IMAG0277.jpg
http://i173.photobucket.com/albums/w59/b18c1delsol93/camaro/12-20239562-165096-960.jpg
http://i173.photobucket.com/albums/w59/b18c1delsol93/camaro/7735_1148646588605_1000790590_30413048_2060652_n.j pg
http://i173.photobucket.com/albums/w59/b18c1delsol93/camaro/7735_1148330020691_1000790590_30411906_6410575_n.j pg
http://i173.photobucket.com/albums/w59/b18c1delsol93/camaro/IMG_2918.jpg
http://i173.photobucket.com/albums/w59/b18c1delsol93/camaro/IMG_2910.jpg
http://i173.photobucket.com/albums/w59/b18c1delsol93/camaro/IMG_2911.jpg
http://i173.photobucket.com/albums/w59/b18c1delsol93/camaro/IMG_2912.jpg
http://i173.photobucket.com/albums/w59/b18c1delsol93/camaro/IMG_2913.jpg
This was the car when purchased her with 83k on it
http://i173.photobucket.com/albums/w59/b18c1delsol93/camaro/redcamarorear.jpg
http://i173.photobucket.com/albums/w59/b18c1delsol93/camaro/redcamaro.jpg
http://i173.photobucket.com/albums/w59/b18c1delsol93/camaro/sideviewcamaro.jpg
Edson
