Nitous questions
Nitous questions
My brother is looking to put nitrous on is 99 z28 with full bolt-ons/3400 circle d stall. I have done some reading and I have some questions. First off what is the cheapest single nozzle wet kit I can get that works good? Second question is what is the easiest/best method for pulling timing? I was looking at the lingenfelter one, but if there is a better one lmk. Third- What plugs should I get?
Things I need?
1. Wet nitrous kit
2. Timing puller
3. Colder plugs
Am I missing anything?
Things I need?
1. Wet nitrous kit
2. Timing puller
3. Colder plugs
complete garbage.. there is no such thing as cheap and works good with nitrous.. its either spend the money and get good quality setup or buy cheap and have nothing but headaches.. save the money and buy from nitrous outlet. they will be doing my new setup for next year
^^^ What he said!!! ............ if you have a cheap set up and just one thing goes wrong and you go lean, you can kiss the pistons goodbye, load the manifold up and it back fires and you can kiss the top end good bye. Get a good plate kit, you will not regret doing it. There just aren't many things in life that are "cheap and good"!
I was told the BR7's are actually too cold for a stock cube car with just a single stage setup. Is there any truth to that? I ran them for a bit and when i took them out they looked nasty.. I am running TR6's with a 150
Been there done that, better at the least double that price. Beleive me, I loved my turbo set-up, but I kinda got to wanting something that was easier to maintain(if you don't mind pulling plugs which I did with my turbo car) and that had the instant gratification that a well put together lightweight cam only car with some dope can go 5's to the 1/8th. Also the wheelstands and violence of the hit compared to a turbo car unless it has 1200+rwhp.
Ok I just bought this kit. What do you guys think? I shouldn't need anything else, but plugs and a timing puller correct?
http://www.ebay.com/itm/170743363757...84.m1497.l2649
Well, you bought it now. Get you some br7ef's in there and the Lingenfelter timing controller. Throw in the 150 jets and get to spraying
