Gm screw in IAT
Old 11-23-2011, 06:54 PM
96TransAmboosted's Avatar
Default Gm screw in IAT
Im almost done with my new turbo project and im going to run a MAF on this car and also wanted to run a screw in OAT sensor. I found one that says its for a megasquirt ecu but im not sure if it will work with my stock lt1 PCM?
The unit comes with a new pig tail and all. Will this work and if not what will?
Thanks Tom
Old 11-23-2011, 07:29 PM
Cam72aro's Avatar
Most use the iat off a gmc cyclone or typhoon from 91 or so. Thats what we run on my car.
Old 11-23-2011, 07:52 PM
JRENIGAR's Avatar
wells part # SU127, GM part # 25036751
Old 11-23-2011, 08:53 PM
SS4Matt's Avatar
I think I used one out of a Turbo Pontiac SunBird lol circa '91 or something as well
Old 11-23-2011, 09:09 PM
4SFEDZ's Avatar
I used the one for a cyclone also
Old 11-23-2011, 09:31 PM
SATAN's Avatar
I believe the one I use is for a grand national. But that is for my AEM EMS. They all send a 0-5 volt signal. But I don't know if they are all scaled the same.
Old 11-24-2011, 07:59 AM
Thank all of you for the very useful information. I like the Typhon IAT sensor. I think I will be using that one.
Old 11-24-2011, 09:45 AM
cadivette's Avatar
Borg Warner makes the parts and you can get BWD parts at local suppliers like O'Reilly or Advanced.
IAT part# WT382
Pigtail part# PT778
Attached Thumbnails Gm screw in IAT-iat-2.jpg   Gm screw in IAT-iat-3.jpg   Gm screw in IAT-iat-pigtail.jpg
Old 11-24-2011, 10:01 AM
Cadivette that's what I needed. Just called my buddy and he said I can pick it up tomorrow. Thanks a bunch to you and every one else for the great help
Old 11-24-2011, 10:06 AM
Restricted User
98Z28CobraKiller's Avatar
IAT part# WT382
Pigtail part# PT778
The sensor pictured here is the one you want. It has the tip extended and exposed which responds the best. I have the other style like the cyclone/typhoon and it does not expose the sensor to the airflow as well and is therefore laggy and heatsoaks. I need to get one of these.
Old 11-24-2011, 01:23 PM
SATAN's Avatar
This is the one that I use. Again, I believe it is for a Buick GN... I THINK.
While we are on the subject. Can anyone tell me which which wire is what? I mean, there are only two but which comes FROM the PCM and then which goes BACK TO the PCM? Or does it even matter?
EDIT: Pretty sure it does matter... My book is telling me that IAT ground is pin 57 black wire on red connector, and that signal is pin 25 tan on red connector (Truck harness). However, That doesn't tell me which side of the pig tail that is. Looking at the picture posted above, both of the wires are black. That doesn't help me. Or again, is it just a therm resistor and it doesn't matter?
Old 11-24-2011, 07:48 PM
4SFEDZ's Avatar
i got the one pictured from advance and i told them i had a cyclone,,,,,sane part number
Old 11-24-2011, 07:51 PM
Cam72aro's Avatar
Mine is the same as pictured and its from a cyclone/typhoon.
Old 11-24-2011, 08:46 PM
SATAN's Avatar
Found my information here
http://www.3si.org/wiki/index.php/In...erature_Sensor
If you are looking at the plug with the clip on the top and the sensor is pointing away from you, then the ground is on the left side. In the link above, it shows red and black wires, that's how I deduced what I did.
Quick Reply: Gm screw in IAT
