Dyno Guesses & Bench Racing Forum - What will she run in the 1/4 mile?
Indyjc
11-24-2011, 08:49 AM
Alright 69 Camaro about 3,000 lbs. ls1-700r4-373 gears. Mods are headers,cold air,ls6 intake,cam,tune, made 377 hp on the dyno. My guess with traction and a good driver (not me) low 13's.
Thanks
s346k
11-24-2011, 08:55 AM
what tires?
on a decent tire i'd be looking for mid 12s with no stall. best case mid-low 11s, but you'd need a big stall and strong 60'.
Indyjc
11-24-2011, 12:26 PM
Thanks, tires are bf goodrich kdw. Forgot the stall it is a Yank 3200. Thanks this gives me a ball park.
s346k
11-29-2011, 03:58 PM
with that setup i'd say mid-12s. your tire will be severely limiting your ability to generate a decent et.
i had a bolt-on ls1 a4 4th gen camaro that went 12.7s on 245 goodyear gscs. i assume you will have the same problem i did with traction, but trap higher due to the lack of weight. the same car went 12.0s on a drag radial, 3700ish raceweight.
mbaker3
11-29-2011, 04:52 PM
Thanks
This would give you a good idea:
http://users.erols.com/srweiss/calcehp.htm
