cam/oil pump torque specs?
Is this necessary? The assembly procedure I followed didn't mention loctite on these bolts so I oiled them and torqued them. The original bolts didn't have any signs of thread locker either.
yes loctite is necessary, IIRC the factory threadlocker is actually applied to the bottom of the bolt head
LSX Mechanic
Remove the bolts, soak them in non-chlorinated brake parts cleaner, spray the holes of the camshaft with brake parts cleaner, let them both dry, reinstall with red loctite.
If you don't, you'll wish you did. Good luck.
Thanks for the info guys. I pulled the bolts one at a time, sprayed brake cleaner into the holes, cleaned them with q-tips, cleaned the bolts with more brake cleaner, and reinstalled with loctite. You guys may have saved me some serious heartache down the road.
