Which E38 PCM & Harness to Use?
Old 11-24-2011, 06:38 PM
The_One's Avatar
Default Which E38 PCM & Harness to Use?
I am starting to piece together all the parts for an LS3 build for my 240SX, and have ran into a roadblock.
I am not sure which E38 PCM, wiring harness, and gas pedal that I need to use.
Seems there are several different E38 PCM's. From my research it looks like they can be reflashed for different vehicles? If that's the case, can I run an E38 PCM from a truck? I found one for a really good deal.
The LS3 shortblocks I'm looking at have some sensors already. Would I need a harness that has provisions for these sensors (ex, using a 08 corvette harness with the 08 shortblock), or can I mix and match (08 shortblock, 09 harness, and some type of E38 PCM)?
Old 12-04-2011, 08:25 PM
The_One's Avatar
BUMP...
No resolution yet...
Old 12-05-2011, 08:56 AM
LS1TECH Sponsor
Ryne @ CMS's Avatar
you can use an you can use any e38 with that harness, just make sure you load the proper operating system , if you use an pre-08 e38 use an 08 ls3 corvette OS, if you use a 09+ e38 use an 09+ ls3 corvette OS, in the 09 they switched something with the e38, and when you mix the and match OS's on the computer it does weird crap, learn that with a sandrail i tuned...
Old 12-07-2011, 10:31 PM
The_One's Avatar
The thing is that the LS3 I am looking at is out of a 2010 Camaro.
Wouldn't I need the engine wiring harness out of that car?
If that's the case, wouldn't I need to use a 2010 Camaro E38 PCM?
It's okay to use an 08 LS3 Vette OS with a an older E38 PCM even though it's a Camaro?
I would figure the sensors and sensor outputs would be different between them.
Old 03-18-2012, 04:38 PM
The_One's Avatar
I ended up buying an E38 PCM out of a 2010 Camaro that has a base tune on it.
Still trying to figure out what harness to run (OEM or custom).
Old 06-26-2013, 02:20 PM
1989GTA's Avatar
Did you ever get that sorted out? If so what was the outcome?
Quick Reply: Which E38 PCM & Harness to Use?
