General LSX Automobile Discussion Non-technical LSX related topics.
what is this called?
Old 11-25-2011, 05:58 PM
RPM Graphics's Avatar
Default what is this called?
the motor i'm swapping has been sitting for a while & i'm trying to change out as many parts as i can. i sent my injectors off to get bench cleaned & want to know the technical name for this part so i can replace it, if possible.
Old 11-25-2011, 06:07 PM
ULTIMATEORANGESS's Avatar
Red face
im probably wrong but it looks like a fuel pressure regulator.
Old 11-25-2011, 06:12 PM
71novaguy's Avatar
i agree with orange. but do they sell that seperate or is it all together with the rail?
Old 11-25-2011, 06:31 PM
rnl35thss's Avatar
Fuel pulse dampener is my guess. I don't see a reference to man. vac. . What's it off of? It would be easier to confirm. If its an 06 vette, def the fuel pulse dampener.
Old 11-25-2011, 06:37 PM
it's from an 02 Camaro SS motor.
is it changeable? or can i take it apart & clean it?
Old 11-25-2011, 06:42 PM
02ws.sik's Avatar
Thats where the extra nawwwwz goes. Im thinking orange got it on the dot.
Old 11-25-2011, 07:07 PM
rnl35thss's Avatar
It is a fuel pulse dampener. The fuel pressure regulator is in the tank on the fuel pump sender (great idea). I'm not sure if its replaceable or not, judging by the snap ring , I would think you could change it, but I'm not sure.
Old 11-25-2011, 07:13 PM
rnl35thss's Avatar
Did some snooping. I guessing you can change it. https://ls1tech.com/forums/generatio...first-try.html
Old 11-25-2011, 07:14 PM
yes, after google searching "LS1 fuel pulse dampener", that's what it is. i'm going to take this one out & see if i can clean it up.
Old 11-25-2011, 11:45 PM
traenknerperformance's Avatar
yeah its the same proceedure as when it was a fuel pressure regulator.... its a fairly unnecesary peice- when they put the regulartor in the tank and they didnt need a regulator on the rail anymore- had tens of thousands of fuel rails made up so they stuck a pulsator in it so they had somthing to plug it up...
Old 11-25-2011, 11:50 PM
the_merv's Avatar
A LS2 doesnt have that on the Rails.
Old 11-26-2011, 05:02 PM
rnl35thss's Avatar
Thanks merv, I realized I pulled the wrong year, make,and model. Didn't go back to verify after it was resolved.
