61 chev 383 LS1 S475 build
Thought i would start a build thread on here for my new family car. Building a street type car for drivability and hopefully long high speed powerskids. I have done 95 percent of the work myself with a helping hand here and there from Bloodbath and sourcing out tuning and gearbox build. Imported the car to Australia from the states in very original condition.
quick vids of my old twin turbo 5L Benz
http://www.youtube.com/watch?v=lHsPA..._order&list=UL
Here is my first run, 13psi boost and shifting at 5500rpm. Was kicked off no cage etc, wanted to try run a 9 sec pass with the 70 shot of gas and shifting at 6500
http://www.youtube.com/watch?v=MDjbB...eature=related
Here is a few pics of the interior before trimming and after. The thing is tidy and has no rust! I wanted the interior to still look stock as possible.
nice sway bar! haha, dude those brake lines....might work..? put them on, looks ok, just need tie rod ends on the car to see lock to lock distance to see if they will hit anything.
Modified the stock fuel tank, to mount to bosch 044 fuel pumps
all painted
New converter
New fuel rails
New springs, shocks and converted to disc brakes
all painted
New converter
New fuel rails
Some autometer gauges in original position
60mm wastegate
3 core alloy rad and thermo fans with shroud
Fully built powerglide
New headlights
Magna fuel pressure reg and gauge
Turbo beanie
60mm wastegate
New headlights
Turbo beanie
AIS meth kit
Hotchkis adj panhard rod and top trailing arm
Lokar accel pedal
ECU and meth controller under the dash
engine in again
trial fitting panels
Lokar accel pedal
engine in again
Turbo has arrived
Lowered the battery tray for turbo fitment
engine bay painted
With a lack of fab tools, this is how i had to make the log manifolds
engine bay painted
