71 Chevelle+LY6+T56,
Old 11-26-2011, 10:47 PM
lownfast's Avatar
Default 71 Chevelle+LY6+T56,
I recently started collecting parts to start this build. I have a 71 malibu and plan to drop in a 6.0 LS engine with L92 heads, ls3 intake and a cam, a t-56 6-speed and some other goodies. Here are few pics to start.
Old 11-26-2011, 10:54 PM
lownfast's Avatar
needed some sheetmetal to replace a bad repair by the previous owner.
new stainless brake line kit, the originals have seen better days
Old 11-27-2011, 08:59 AM
veltboy618's Avatar
Looking good
Old 11-27-2011, 09:16 AM
chuckd71's Avatar
Always good to see more 71s.
Old 11-27-2011, 12:10 PM
vandal699's Avatar
what headers, mounts, oil pan and radiator you using?
Old 11-27-2011, 03:06 PM
Doug G's Avatar
Looks good so far.
Old 11-27-2011, 09:55 PM
lownfast's Avatar
hooker abody LS swap headers, ebay mounts that i modified, fbody pan, and a griffin LS swap radiator.
Old 11-28-2011, 10:22 PM
lownfast's Avatar
Old 11-28-2011, 11:11 PM
bczee's Avatar
Yeah.. Another 71' !!.. Anyway... I'll be watching..
What did you do to coat the Frame.. looks like you just took it and had it sprayed or coated. Are the plans now to replace the suspension part ?
BC
Old 11-28-2011, 11:51 PM
lownfast's Avatar
BC
i actually found another frame, had it blasted, epoxy primed and painted gloss black, i plan on replacing suspension pieces as i go, but doing everything in the rear now, i dont feel like fighting it under the car.
Old 11-29-2011, 12:05 AM
bczee's Avatar
Yeah.. I hac my frame and Suspension as a roller and then dropped the body back on after I assembled all of it 1st.
keep the posts coming
BC
Old 12-03-2011, 09:06 PM
lownfast's Avatar
Old 12-07-2011, 08:29 PM
lownfast's Avatar
taking it to the media blaster in the morning to shoot the firewall and underside of the car to see how far i need to go with rust repair.
Old 12-08-2011, 05:48 AM
Rucumn's Avatar
Are you modifying the fbody pan so it doesn't stick below the crossmember or are you just going to run it as is and put the engine a little higher? I know some folks on here who haven't lowered their cars very much have added some gussets under the crossmember to protect the pan.
Great project, keep us updated!
Old 12-09-2011, 07:06 PM
lownfast's Avatar
from what ive seen it wont hang below the crossmember, ill see when i get there.
Old 12-11-2011, 03:53 PM
lownfast's Avatar
she is blasted and back at home getting some epoxy primer and gloss black
Old 12-12-2011, 09:33 PM
lownfast's Avatar
Self etch primer sure is high dollar but its a great start. Painting the underside black, and goin to shoot some 2K over the fire wall before i spray the secret color, and the motor gets fitted.
Old 12-12-2011, 09:36 PM
lownfast's Avatar
passenger foot rust hole
driver foot rust hole
passenger cowl rust
driver cowl rust
Old 12-19-2011, 06:26 PM
lownfast's Avatar
bottom of the car is painted and my UMI lower arms came in, now i can make the new frame a rolling chassis. nothing stopping me from putting the body on it now!
pics!
Old 12-19-2011, 06:37 PM
nos487's Avatar
Looks good keep it up with the pics.
Quick Reply: 71 Chevelle+LY6+T56,
